Results 1 to 5 of 5
Thread: Line-In mute on startup.
    Jun 2003
    Memphis - TN
    Anyone know of a program or an AutoIT script that will mute the
    LINE-IN?
    Because the car2pc.exe causes my radio LCD to flicker, I have to use the winamp plug-in, along with the car2pc plug-in. Unfortunately, this causes the Winamp to play along with the XM and I have to stop the music player or XM on startup.
    If I had this small program it would atleast remove the annoyance.
    That is of course someone wants to help me fix the car2pc.exe Unfortunately no ones modified version has seemed to help us Mazdaspeed 6 owners. The was one that seemed to help a little, but didn't eliminate the flicker. Its odd it works perfect with the winamp plug-in, but not the RR car2pc plug-in.
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    ExecTBL.ini:
    Code:
    "ONSKINSTART","BYIND;LINEMUTE;LINEMUTE<<"
    I *think* that might work...
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    Jun 2003
    Memphis - TN
    didnt work
    Aug 2006
    Sun Diego
    Okay...
    How about this:
    Code:
    "ONSKINSTART","BYIND;LINEMUTE;MUTE;LINE<<"
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    You need to look at the windows mixer and find the name of the mixer you want to mute.
    XP in this case, the mixer is called "LINE IN" so, you would need..
    Code:
    "ONSKINSTART","BYIND;LINEMUTE;MUTE;LINE IN<<"
    That should work.
  1. RR unmutes line in and mic on volume change
    By diosagain in forum Road Runner
    Last Post: 02-07-2008, 10:00 PM
  2. Tutorial for installing pycar on Linux
    By kbyrd in forum PyCar
    Last Post: 11-01-2006, 12:59 PM
  3. Problem compling rr with latest source code
    By Sonicxtacy02 in forum Road Runner
    Last Post: 07-02-2006, 05:08 PM
  4. Techies - matching line output levels ???
    By slushieken in forum Car Audio
    Last Post: 09-10-2004, 03:57 PM
