Page 3 of 6 FirstFirst 123456 LastLast
Results 21 to 30 of 58
Thread: *** NEW HDRadio DLL V1.3.0.0 ***
  1. #21
    MySQL Error
    Oct 2004
    ok, so in HDRADIO PCR app, it needs to write to a config file
    i guess u set up the "EWF" to allow it?
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  2. #22
    Sep 2005
    Hey mitch, Did anyone ever figure out how to fix the problem with the volume being real loud when you go into HD radio from roadrunner? I'm using the digital FX skin and when I first turn it on, its really loud but then when I change a station to something else and then back, its the normal level again.
    I also lose my preset stations when I use navigation but that is probably a roadrunner problem only.
  3. #23
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Quote Originally Posted by blk02si View Post
    Here is what runs my whole system \/ , media is on a standard 80 gig 3.5 drive.
    Hey blk, how tall would you say the CF adaptor + card is? is it about as tall as a 2.5" HDD?
    Reason I ask is that I was able to get my hands on an artigo and am researching whether or not I could stuff a CF IDE adaptor + CF in place of the 2.5" HDD in the artigo case.
    TIA!
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
  4. #24
    Apr 2007
    Got mine running -- THANKS MITCH!!
    My problem was floating grounds from hdz300. DO THE AUDIO MOD!!!
    also, on the config file, I'm running app config data to ramdrive, so I had to create a user.config file and copy it there on boot.
    XPE rocks!!! (if you get an hp thin client, you get it for free, as well as the xpe tuned .net20 install, etc... makes xpe extremely simple)
    Thanks again, I have AWESOME RADIO... never knew fm could sound so good (but maybe that's the eql, soundstream amp, boston speakers, JL audio sub...)
    and the music is coming from usb 16gig sticks.... so no hard drives....
  5. #25
    Variable Bitrate eric_barcus's Avatar
    Mar 2007
    Quote Originally Posted by jjakes24 View Post
    anyone know how to set the max volume allowd or the startup volume it really is quite loud
  6. #26
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Quote Originally Posted by eric_barcus View Post
    You can use the SETVOL command for this on the RADIO button.
    B01,,,,,"RADIO||SETVOL;AUX;5"
    Where AUX is your line in where the tuner is pluged in.
  7. #27
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    Hey Sal, the flash module is smaller than a 2.5" drive, about 1/2 the thickness.
    Personally I would go with this model instead. Its a "male" version of the same adapter that plugs directly into the motherboard. The red one is a "female" version that plugs into a IDE cable. This is my tester flash module for determining if a system is suitable to boot from flash. Its running DOS If PC hardware will boot DOS, it will most certainly boot Windows.
    I am going to be updating the car PC shortly, and this DLL is on the list.
  8. #28
    Mar 2007
    RADIO||SETVOL;AUX;5
    where does that go? sorry new to the coding thing in rr
    does it go in the rr.ini file?
  9. #29
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    That is the button command in you menu.skin where you click RADIO. Use the skin editor and change the button code there.
  10. #30
    Mar 2007
    updated to this driver and it hangs, will not switch to the HD2 channel, never restarted pc after new dll file was copied is that needed?
  1. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 08:55 AM
  2. Calling C# or VB6 DLL from RR
    By Evolution VIII in forum Road Runner
    Last Post: 01-09-2006, 01:57 PM
  3. Replies: 3
    Last Post: 08-30-2005, 01:45 PM
  4. error - DLL Missing
    By dan__wright in forum AutoTouch
    Last Post: 05-19-2005, 01:12 PM
  5. Replies: 9
    Last Post: 03-31-2005, 02:40 AM
