Results 1 to 6 of 6
Thread: GPS clock setting car clock
    Maximum Bitrate bes51659's Avatar
    Sep 2005
    Vasastaden, Stockholms Län, Sweden, Sweden
    The GPS has very accurate time from satellites. Very simple to decode from NMEA message. Has someone used it for setting time in PC and/or car? (specifically RR and BMW IBus)
    NMEA message:
    $GPRMC,132307.93,A,5921.39377,N,01758.66388,E,000.0,000.0,230408,,,A*53
    23 min past 1PM, 23 april 08
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    RoadRunner has a function for settng your PC time/date.
    As for setting the Car clock along the iBus, now that is interesting (for those that have iBus). There are plugins that can communicate with the iBus it would just be a metter of finding out the right code (if it is possible)
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quick serch found this
    Code:
    From http://autos.groups.yahoo.com/group/HackTheIBus/message/7428:
    Q: How to SET the clock via the i-bus? GT telling IKE to set the time: 3B 06 80 40 01 0C 3B CB GT –> IKE : On-board computer set data: Set Time = 12:59 3B = GT 06 = length 80 = IKE 40 = OBC Set data 01 = Time 0C = hours in hex, eg: 0C = 12 3B = minutes in hex, eg 3B = 59 CB = checksum GT telling IKE to set the date: 3B 07 80 40 02 1B 05 08 E8 GT –> IKE : On-board computer set data: Set Date = 27/05/08 3B = GT 07 = length 80 = IKE 40 = OBC Set data 02 = Date 1B = day in hex, eg: 1B = 27 05 = month in hex, eg: 05 = 05 08 = year in hex, eg: 08 = 08 E8 = checksum
    Sep 2005
    That's great! Thanks for IBus messages!
    So I can use GPS gate to set up a new COM port with NMEA data and read it into a new GPS_Time_RR plugin. That date and time will be fished up by the IBus RR plugin that will set the car clock to the same time as GPS and RR clock.
    Fun!
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    I would be very carefull on this... This functionality is alread in roadrunner, but Guino has found that different GPS Receivers return very different formats even though it is supposed to be in a standard format. Just search and you will see some posts where he tries to get it working correctly all the time and just gave up because of the differences between the receivers.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Sep 2005
    Ahaa! The date format!
    GPS date/time sync behavior
  1. Car GPS wire connecters
    By Zo6om in forum GPS
    Last Post: 10-12-2007, 07:01 PM
  2. How to put the GPS antenna out of the car?
    By jonmurua in forum Fabrication
    Last Post: 08-18-2005, 11:55 AM
