Results 1 to 5 of 5
Thread: Cannot start RR when it has GPS fix?!
    Feb 2006
    Hi all,
    Basically the problem is this. When I have GPS fix and try to start RR, it would hang at the screen where it is supposed to start Winamp. I need to Ctrl-Alt-Del to get out of the screen. But if it start RR before the GPS receiver has acquired a fix, everything is okay.
    Now obviously this has something to do with GPS attenuated volume and how RR sets Winamp's volume, but I am not exactly sure how. If I disable GPS attenuated volume with RR Config, everything works, but obviously I don't want to do that.
    Any idea?
    Spec:
    - XP Pro
    - BU-353 receiver (COM3 split to COM8 and COM9 by Xport)
    - RR Dec 2007
    - LSXVoid 3.3
    - Winamp latest
    Thanks.
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Try winamp 2.95 or 5.13.
    Later versions of winamp had problems w/ attenutated speed.
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    May 2006
    Simi Valley, CA
    Does winamp load on it's own?
    It's been my experience with the latest winamp that it takes forever to load sometimes.
    It could be just taking longer that you're willing to wait.
    Either way, you shouldn't probably go past v5.33
    Maximum Bitrate Woofnstuff's Avatar
    Oct 2007
    Auckland
    also check that your GPS splitter and RR are not using the same gps serial port.
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    delete the ziplocator.dll in your road runner directory, also make sure the skin ur using doesnt have any X,PLUGIN lines in menu.skin.
    Live mp3Car Facebook Chat
  1. Replies: 65
    Last Post: 10-13-2009, 07:51 PM
  2. RR Not Responding
    By Surferx14_2 in forum RR Bug Tracker
    Last Post: 06-06-2008, 09:56 PM
  3. The GPS Locks up RR!
    By wsudu in forum Road Runner
    Last Post: 09-10-2007, 12:17 PM
  4. Getting Started with GPS
    By grepzen in forum The FAQ Emporium
    Last Post: 09-26-2006, 06:54 AM
  5. Replies: 7
    Last Post: 02-09-2006, 08:42 AM
