Results 1 to 3 of 3
Thread: D-Link DSB-R100 through mic jack?
    Unfortunatly my laptop only has a headphone and mic jack, and no line in. So far I have been unsucessful in trying to get things to work this way using the built in RR support.
    I know the mic is working fine because if I run RR and tune to a station, then do the "Test Hardware" in the sound settings, it shows that it is receiving audio through the port, it's just that nothing is coming out of the speakers. I have a Dell laptop with Sigmatel audio drivers.
    Does anyone have any suggestions on how I can use the mic jack for the radio receiver; short of buying a USB sound card with a line-in?
    Maximum Bitrate v8 scimitar's Avatar
    Jan 2005
    I assume you have un-muted the mic in the output section of the sound mixer? Pretty sure you also need a plug-in for winamp to get this to work as well if you don't already have it. Its been a while since I did this and I gave up on it because of poor reception so my memory is a bit vague on it.
    Visit my site V8 Scimitar
    SP13000, 300GB SATA HD, 1GB DDR. Opus 150, K301 screen, Cisco WIFI, AQmax GPS, RoadRunner and FreeDrive, Sony MEX-R5 head unit. 4 years installed and it just keeps running!
    Yea, it's un-muted and receiving sound just fine. It's just that my laptop does not replay the output from the mic through the speakers to try to prevent feedback when using things like Skype. Unfortunately with no line-in, I'm stuck that way.
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. Rugged Vehicle PC with Front End (Links @ end / Long Post)
    By Tower Boss in forum General Hardware Discussion
    Last Post: 04-08-2007, 08:36 PM
  3. Weird Mic Problem.. Help!
    By veetid in forum Car Audio
    Last Post: 09-30-2006, 08:05 PM
  4. IBM T42: disable onboard speakers and microphone using port replicator II
    By WhiteRabbit in forum General Hardware Discussion
    Last Post: 11-18-2004, 05:52 AM
