Results 1 to 10 of 16
Thread: Cant Figure out the Label Shuffle/Repeat Indicator
    FLAC -zip-'s Avatar
    Ontario/Canada
    Hi Guys,
    Tried to make a label indicator for the shuffle/repeat button
    When I click on the shuffle repeat button the indicator does squat, what am I doing wrong?
    Code:
    "BYIND;SHUFFLE/REPEAT;=SHUFFLE/REPEAT OFF<<=SHUFFLE<<=REPEAT"
    Sound Stage
    Eclipse|MTX|Infinity
    Feb 2007
    netherlands
    The code for the button: "SHUFFLE/REPEAT"
    code for shuffle indicator: "SHUFFLE"
    Do you have the indicator picture on your down picture ?
    otherwise open the bmv skin in one editor and your own in another and coppy the code.
    FLAC -zip-'s Avatar
    Ontario/Canada
    Trying to use the text/label method as opposed to adding a picture with an on/off indicator.
    Sound Stage
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Use an indicator ("I") definition with the command "shufflerepeat" - it will show the words.
    FLAC -zip-'s Avatar
    Ontario/Canada
    ugh cant seem to get that going. "Shuffle/Repeat" using I (Indicator). I do use the Label Indicator for mute, works like a charm, did some reading on the boards some people have done it using L (Label).
    Sound Stage
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    for label to show like mute or shuffle/repeat try this
    L,569,487,101,44,255,0,0,23,"Arial:B","BYIND;MUTE; = <<=Mute","CENTER"
    I,568,480,103,49,"MASTERMUTE"
    you can have IND line anywhere you need it and same for the label.
    just change the word Mute in the Label line for what ever word you want to use.
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
    FLAC -zip-'s Avatar
    Ontario/Canada
    My first post above, I tried this.. I bet is some ; or " out of place or something...
    Sound Stage
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    Quote Originally Posted by -zip- View Post
    correct
    FLAC -zip-'s Avatar
    Ontario/Canada
    What it does with this code is on the skin it shows Shuffle/Repeat and does not change to "Shuffle" or "Repeat" hitting the buttons. It just stays Shuffle/Repeat.
    If that makes any sense LOL.
    Sound Stage
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    BYIND;SHUFFLE/REPEAT;=<<=SHUFFLE<<=REPEAT"
    you have to use SHUFFLE/REPEAT as your IND line this will toggle between the too
  1. Set Label to dsplay Variable
    By mukow in forum RR Skins
    Last Post: 03-07-2008, 12:03 AM
  2. Flash Skin Tutorial?
    By Cruizer in forum RR Skins
    Last Post: 01-10-2008, 12:02 PM
  3. Scrollable Label?
    By JWise1203 in forum CF SDK
    Last Post: 11-03-2006, 11:21 PM
  4. My Online Indicator
    By F350 in forum Road Runner
    Last Post: 10-05-2005, 04:18 AM
  5. M1-ATX - Q2 part label - please help
    By cclass in forum Power Supplies
    Last Post: 08-07-2005, 02:14 AM
