Originally Posted by
monkeyracer
john, I have a question for you.
I know you were dabbling with ShutControl for a while, and on the thread for the shutcontrol we can use the "Taskkill.exe" with some switches to kill certain programs.
But do you know of a way to properly close down an application, using your kill_task.exe, or any other means?
If I suspend with winamp running, on resume it loses the playlist. If I kill winamp, it loses the playlist, and reverts back to a different list with only one album. If I close winamp (with RR) and then suspend, I can have Shutcontrol resume RR (along with winamp) and everything works correctly.
fyi - I suspend rather than hibernate since it's way quicker...
So, how do we do this?
Figured it out in autoit. VERY simple script:
Code:
WinClose("RoadRunner", "")
Compiled into an .exe, so to get this to work right, download the attachment, rename it without the .txt, then in shutcontrol set this as a pre-hibernate app, and then set RR as a resume hibernate app. No more lost playlists. I set it to run "RRClose.exe" at least 5 seconds before the Suspend routine, just to be sure.
edit: I should note that this only works when you set shutcontrol to hibernate, any other routine does not trigger the pre-hibernate apps.
