Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: application shutdown on rr exit..
    Dec 2007
    Now, does anyone experience that some of the ext. embedded app doesn't get shutdown when you exit RR?
    It closes ig4, and other plugins..winamp most of the time.. even closes mpc, but, some of the application, it doesn't.... Is this a known issue, or am i doing something wrong? I like to have everything close on rr exit... i also set that flag in rrconfig too... What am i doing wrong?
    Thanks. shoot.. screwed up the title... sorry....
    Wants to make it harder monkeyracer's Avatar
    May 2007
    Lakehood, CO
    You can edit the thread title by double clicking it in the subforum or by changing to the more advanced editor.
    I have an issue where it sometimes doesn't want to close winamp. For example; I'll make some changes in skineditor, and load RR, close rr, make more changes, load rr to test and since winamp didn't close properly, there are two instances, and rr doesn't know which one to pull info from. So I have to open up task manager, close all instances of winamp, and restart RR. I don't seem to have this issue with any other program, RR closes them fine, just winamp. I can try the "CLOSEWINAMP" code, but I test a lot of skins, and it's fairly annoying to add that to every skin I test.
    @OP - from the skincommands.txt:
    "CLOSEWINDOW" - This allows you to close any running application based on the given window title. The application may request the user to save any unsaved data before closing, so beware.
    Example: "CLOSEWINDOW;Notepad"
    So whatever applications are having issues, just put this code after double pipes || to close out the stuff that RR didn't (but RR should just close anything that is embedded) on your exit button.
    2007 Chrysler PT Cruiser TE
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
    Favorite thread EVER!
    Dec 2007
    I can live with the way wimamp not being consistent.. but, other applications it just won't close at all... I want something like this monkeyracer, "shutdown||closewindow" but, that wouldnt' work as you know.. Is there something like this, "closeAllOpenWindows"?
    May 2007
    Lakehood, CO
    it would be:
    "SHUTDOWN||CLOSEWINDOW;"
    This would close EVERY open window, I haven't tested it, but with nothing after the semicolon rr will tell windows to close any program with a windows name. (I think you just need to add the semicolon to the code.)
    or to close specific windows:
    "EXIT||CLOSEWINDOW;Notepad||CLOSEWINDOW;Inbox||CLO SEWINAMP" And so on, you shouldn't have more than a few programs embedded into your skin, so it shouldn't be too hard to do this.
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    In rr.ini:
    closeapps=true|false
    Close any open embedded applications on exit
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    Dec 2007
    hmm... no luck... well.. i just gonna have to close it explicitly..
    let me try that Sal...
    well... just confirmed it was set to true...
    closeapps=true
    Aug 2006
    Sun Diego
    What version of RR are you using?
    I use a few external apps (VAG-COM, System Manager, Filemanger, Notepad, etc.) embedded and they all close when I exit RR.
    Dec 2007
    dec 13 2007.... It won't close garmin mobile pc it still runs after rr being out...
    May 2007
    Lakehood, CO
    If that's the only program that doesn't close, either add the windows name to
    embedapplist=[windows name]
    in rr.ini,
    or use the CLOSEWINDOW;[windows name]
    Just replace the [windows name] with what the actual windows name is (winspector spy will help find this)
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    some app's dont close at all when exiting, freefone, imageviewer, and rainlendar are the ones i know for sure they always keep running. sonic added a command 'ONEXIT" (i think)to one of his beta's, hope it makes it to the official soon.
  1. Replies: 45
    Last Post: 09-10-2008, 10:54 PM
  2. Why do people think RR is hard to setup?
    By 2k1Toaster in forum Software & Software Development
    Last Post: 05-18-2008, 01:38 AM
  3. RR is acting really slow... debug.txt attached
    By ludikris in forum Road Runner
    Last Post: 04-11-2008, 01:35 PM
  4. XMD RR Hibernation & XMRESET
    By hank_kls65 in forum Road Runner
    Last Post: 10-25-2007, 04:14 PM
