Results 1 to 3 of 3
Thread: HDRadio & Roadrunner (will not turn on)
    Constant Bitrate mpfjr's Avatar
    Jun 2004
    Corona, CA
    Ok, so I installed the latest PCR software off of mitch's site. Have the HDZ300 unit hooked up correctly. Got it working for a while using the software but could not get it working with Roadrunner.
    Latest Road Runner comes with the files in the HDRadio folder. I ran that "runmefirst.cmd" and did all that. Set up rr.ini according to mitch's instructions. When I start HD Radio (using digitalfx 3.0) it doesn't click on.
    Tried an updated .dll file dropped into that same directory and still nothing. If I plug in the little control unit the HD Radio comes with I can tune in stations and listen to them etc. If I use mitch's pcr software it works too. Just can't get RR to switch it on when I hit the hd radio icon. Is it a skin issue or a RR issue or something else?
    Now I have a new problem. Found out I didn't have the HD Radio unit (black wire) grounded. It was routed up where I as going to ground it but it wasn't grounded. So I fixed that but now when I run the PCR software it immediately generates an error and I have to exit out. So now the unit ONLY works when I use the controller box. Maybe my battery is low and there is not enough amps/volts? Could be. I have it charging and I'll test it tomorrow. But that still doesn't solve the problem with the unit not starting (powering up) withing RR.
    My RR.ini says
    [Radio]
    radiomode=8
    allowallfreqs=false
    radioline=5
    userbds=true
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    hdradioport=<enter com port>
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    Jun 2004
    Corona, CA
    Quote Originally Posted by Sal R. View Post
    Thanks I'll try that in the morning.
    Edit/update: That did the trick thanks!
  1. Mappoint and Roadrunner Error
    By 0statik in forum GPS
    Last Post: 07-05-2006, 11:46 PM
  2. AMP wont turn ON!! HEELP!
    By pdjafari in forum Car Audio
    Last Post: 10-15-2005, 07:43 PM
  3. PC wont turn on....
    By Cheekz185 in forum General Hardware Discussion
    Last Post: 08-18-2005, 12:27 PM
