Results 1 to 10 of 11
Thread: DVD and auto sync questions
    Constant Bitrate smp4488's Avatar
    Oct 2007
    Louisville, KY
    I have been working on my car pc forever. I started after x-mas and it is still not in. Im almost done i just need to tie up a few loose ends.
    First, i cant get road runner to go full screen, i have tried all of the resolutions in the config program and the normal and wide screen aspect. The old config program had a full screen option but it is now gone.
    Second, what dvd program should i use? I have used power dvd on my computer before but never in a car pc. I dont know how it would do with the touch screen.
    Third, i am looking for a program to auto sync my movies and music when i connect to my home network. I was looking at upd8 but i cant seem to download it to give it a shot. Any other suggestions?
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    1. what size is your screen?
    2. try the inbuilt player first, then either powerDVD or WinDVD, both should work depending on skin used you may have to use an older version though if they have changed the hot keys.
    3. Have you registered on my forum? (and if so what username did you use, because it wasn't smp4488 I take it)
    Oct 2007
    Louisville, KY
    1) It is a 7" lilliput
    3) I tried to register but it locked me out for too many attempts. I dont think i couldnt get the code right.
    Oct 2007
    Louisville, KY
    1) I'm not sure on the resolution. I think it is 800 x 600 but dont quote me.
    3) I got it it just needs to be activated.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    What skin are you using?
    Most run natively at 800x600 others at 848x480, so make sure you screen is running at one of those resolutions.
    Activated
    Oct 2007
    Louisville, KY
    LSX Void 3. I had it working fine before when the road runner config had the full screen option.
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Browse to the skin folder and look for the files GENERAL.ini
    Look at these lines.
    OriginalWidth=800
    OriginalHeight=600
    ShowWidth=800
    ShowHeight=600
    XPosition=0
    YPosition=0
    Leave the originals alone and change the ShowWidth and the ShowHeight to you monitor resolution. If you have the 7" Liliput widescreen, then the line atop apply.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    isn't the LSXVoid run at 848(800)x480.
    And there for e the above should be
    OriginalWidth=800
    OriginalHeight=480
    ShowWidth=800
    ShowHeight=600
    XPosition=0
    YPosition=0
    if he is using standard res of a lilliput 7"
    Variable Bitrate chevyn8's Avatar
    Oct 2006
    small town nebraska
    Display Properties/Settings (look at the resolution)
    General.ini needs to match (show settings). In RR config use default for screen resolution.
    Built in DVD is simple and works good IMO.
    I use foldershare to keep video/audio in sync for close to a year and it seems to work.
    CarPC in my 82 Camaro. Dual core atom, M4-ATX, 7 lilliput, bu353 GPS, Reborn skin, punch 40/100ix
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
  1. Auto CD / DVD Insert with definable actions
    By JohnWPB in forum RR Plugins
    Last Post: 08-11-2008, 12:17 PM
  2. Auto Play DVD with MPC
    By Kurack in forum Road Runner
    Last Post: 03-09-2008, 07:20 PM
  3. How do you get WMPC to auto start DVD?
    By TSur in forum Road Runner
    Last Post: 05-14-2007, 02:45 AM
  4. dvd auto play on disc insertion...
    By Hell-Stopper in forum Road Runner
    Last Post: 01-16-2006, 08:11 AM
