Results 1 to 7 of 7
Thread: How to combine "strings" ?
    Maximum Bitrate Valheru's Avatar
    Jul 2007
    Ireland
    Is it possible to join two strings in RR using just RR Commands ... I'm trying to create a new filename based on the current songs's name, so if the current song is "c:\music\song1.mp3" and this is stored in the "TRACKPATH" varible, can I append a string onto the end of this variable to give me something like "c:\music\song1.mp3.abc" ...
    thanks ... valheru
    The TEKNIK Family ... Teknik 1 & Teknik 2, Teknik T-3, Teknik v4.0, Teknik-X.
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    I think you can do this by combining 2 variable
    "SETVAR;MYSTRING;$TRACKPATH$++= ++$ADDEDSTRING$"
    Then MYSTRING should contain "c:\music\song1.mp3 addedstring"
    Jul 2007
    Ireland
    this is the command I'm trying but the file does not contain anything ...
    SETVAR;MYEXT;ABC||SETVAR;MYSTRING;$TRACKPATH$++=++ $MYEXT$||WRITETOFILE;$skinpath$support\rate.txt;$M YSTRING$
    any ideas ?
    basically I want to take the name of the currently playing song and append a "ABC" to the end of it ... thus creating another file based on the name of the current song ?
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    If it is alway ABC then try this. Rename to .exe
    Attached Files Attached Files
    Jul 2007
    Ireland
    thanks MGD, yep .. that is exactly what i was trying to do with the strings, but now only if I can get it to work in just RR code, i was really hoping not to have to use a script ... back to the drawingboard for me then ..
    Jul 2007
    Ireland
    that worked Enforce .. thanks ... just needed to convert the Labels to Variables using SetVarByCode ...
    thanks guys for your help ...
  1. using a mixer to combine audio
    By OpeRand in forum Newbie
    Last Post: 03-17-2006, 03:34 PM
  2. How to combine Maps??
    By seabeggar69 in forum Map Monkey
    Last Post: 10-15-2005, 04:40 PM
  3. off topic- how to combine pictures?
    By organasised in forum Off Topic
    Last Post: 03-12-2005, 08:12 PM
  4. can i combine 2 PSU to get more power?
    By jusatry in forum Power Supplies
    Last Post: 05-20-2004, 09:09 PM
  5. Replies: 5
    Last Post: 08-30-2002, 11:04 AM
