I have the same problem but it only seems to happen after I use Iguidance for navigation. Would love to find a solution.
Hi,
I just got my HD Radio working with Mitch's cable, really nice stuff. However, I'm having a problem with Road Runner and the line-in. RR does unmute my line-in, which is good. But for some reason, the volume is set to the lowest and I have to manually change it so that I can hear the radio.
Anyone got an idea why my line-in's volume gets set to the lowest?
Hmmm... that might explain the "randomness" of it. So iGuidance is the culprit? I'll test that tomorrow. Btw, any solution? Maybe using the winamp line-in plugin?
I haven't figured anything out yet. Not even sure if it only happens when using Iguidance, I just noticed there might be a connection. I also lose all my presets in the HD radio skin. So bizarre. I might just put a button in the HD radio skin that executes a program that raises the line in to a certain level and unmutes it.
What about adding a command to your exectbl.ini to increase the line-in volume when you open the hdradio skin?
It's actually pretty easy. It's a setvolume command.
What skin are you using?
DigitalFX 3.0
Of course you had to pick the most complicated skin.....
I need to do some more poking around.
