Results 1 to 5 of 5
Thread: quicky?
    Variable Bitrate eric_barcus's Avatar
    Mar 2007
    quicky?
    im using RR and LSXVOID and i have the transparent AVS set up but it "transitions" to a new visual every 45 seconds or so, i had it installed previously where it would stay on one visualization but now it cycles through them and i cant just pick one to view always,
    is there a setting in RR its self or in the VOID skin?
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    Quote Originally Posted by eric_barcus View Post
    open winamp standalone no rr ctrl - p i think , should high light visual select advance visual studio in the right pane,start at the bottom , then configure, new window select settings from the drop down menu /presets, decheck random every 10 sec's.
    also check the rrconfig i think that has a change setting in it too
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
    Mar 2007
    ill look for the winamp setting but do you know the RR setting?
    PS i found the winamp setting (on my work virtual machine) and will be looking in the car at lunch to see if it fixes)
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    rrconfig under music page 2 fade interval
    Mar 2007
    set to 0?
  1. Bluetooth quicky.
    By konnichiwa in forum Newbie
    Last Post: 09-21-2005, 03:40 PM
  2. Quicky Programming ?
    By IntellaWorks in forum Software & Software Development
    Last Post: 03-20-2005, 09:01 PM
