"INDICATORNAME:b" b as for blinking.
It's all in skincommands.txt
How do I set up a blinking indicator?
Searched and cant find anything.
thanks
I thought it might have to do with a timer command or something.
Super simple solution for a super simple guy.. me...
thanks for much
Cliff
Didnt work. Do I need something else????
It has to work...
Do you have an OFF ON layer in your specific skin file? Look at the first lines.
RoadRunner Skin
RRScreen F-CNS(800x600Stretched)"audio
Then you need two different images. Attached are two test images with the OFF and the ON state. Place the indicator over the words MUTE OFF with the code
"MASTERMUTE:b" and it will blink red and black as in OFF/ON.
On the Button "MUTE" have a command "MASTERMUTE" ahh what the hell, here is a test skin. Load it from your menu.skin with the command "MENU;TEST.skin"
Copy and Paste, save it as TEST.skin
RoadRunner Skin
RRScreen F-CNS(800x600Stretched)"test
Mute_off.png,Mute_off.png,Mute_down.png,Mute_down. png
B,104,121,166,63,"MASTERMUTE",
B,332,121,166,63,"EXIT",
I,146,61,324,51,"MASTERMUTE:b"
END
I bet I dont have a on jpg that is on... I will check when I get home..
My on jpg was the same as my off...
stupid rookie mistake..
thanks for all your help.
