Results 1 to 4 of 4
Thread: close application
    Maximum Bitrate jonessc's Avatar
    Nov 2006
    Wales, UK
    Question close application
    Im working on a GPS skin, and have added an exit button with the code "CLOSE" that works perfectly.
    Now instead of closing ive got it to load a skin with a close confirmation yes/no button (see pic)
    How can i get the GPS program to close the same way, seen as it wont be in focus anymore for the "CLOSE" command to work.
    Code for confirmation skin:
    Code:
    RoadRunner Skin
    RRScreen "CONFIRM"
    [Yes/No Button]
    B01,19,299,105,86,"","CLOSE GPS"
    B02,375,299,105,86,"BACK","ABORT"
    /DISCARDABLE
    END
    CarPuter Progress:
    Planning:-----> [||||||||||] 100%
    Hardware Buying:-> [||||||||||] 100%
    Software:-----> [||||||||||] 100%
    Installing:-----> [||||||||||] 100%
    Current Project= Making skins in photoshop...
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Any application that RR loads, and is embedded correctly, should be closed when you exit Road Runner.
    When I close RR, Winamp, iGuidance and all programs that RR started are also closed.
    To close something manually, see this thread, and have a look at post #12. This can be set to end task any program running on the system, regardless if RR opened the program or not.
    My Fiero Build Thread
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    You can also use "CLOSEWINDOW" command if you know the specific window's window name.
    Judging from your other thread, you do.
    "CLOSEWINDOW;$gpsname$"
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    Nov 2006
    Wales, UK
    Quote Originally Posted by Sal R. View Post
    Good point, that should then close whatever GPS window has been set in the rr.ini (on the subject of that other thread i'm still trying to solve the last bit of code but the rest is working well)
    Quote Originally Posted by JohnWPB View Post
    Thanks John, it does close when I exit RR, but the confirmation to close app will appear over the GPS skin, il have a look at it.
    CarPuter Progress:
  1. Sample VB application to control a Fusion Brain
    By mx270a in forum FB Software
    Last Post: 10-09-2010, 01:19 AM
  2. Skin Embedding Application Problem
    By JohnWPB in forum Road Runner
    Last Post: 04-19-2008, 05:41 PM
  3. Set RR to close a program ... not hide
    By drPheta in forum Road Runner
    Last Post: 08-23-2006, 11:19 PM
  4. Problems embedding GPS application properly
    By Tim K in forum Road Runner
    Last Post: 07-27-2006, 11:26 PM
  5. Subwoofer Placement-magnets too close?
    By ddt in forum General MP3Car Discussion
    Last Post: 03-23-2003, 01:49 PM
