"Sendkey;^{F4}",""
Should do it
I am trying to make a skinpage for the Hauppage Wintv, But i need to work with send key to get it to work.
To close the application alt+F4, only then in code.
I know ctrl = ^ now only need to know the rest.
So a list of the commands would help me a lot te get the skin-page off the ground.
"Sendkey;^{F4}",""
Should do it
Searched the web, and came acros this, are these the same codes as used in RR to program sendkey commands? So Alt F4 = %{F4} ?
http://www.codeproject.com/KB/cpp/se...p_Article.aspx
key code:
shift = +
ctrl = ^
alt = %
yeah, sorry thought you had the first bit, didn't realise you changed from CTRL to ALT. (didn't read carefully enough)
is there one for the windows key? thought it was @ but it doesn't work (well for me), anyone get this to work?
example i want to send the command WINKEY + CTRL + right arrow i thought it would be "SENDKEY;@^{RIGHT}" but that doesn't work.
Thanks!
james
The Windows Key is (in many cases) the same as CTRL+ESC, you should try that.
Ride Runner RR's Myspace
that's a good idea, but it doesn't work. doh. probably an autoit script can do it, but before i go there, any other suggestions? thanks!
james
I do know that in AI the win key = # sign. Try that..
Current Project: DFXVoice [Beta Released]
Next in line: RRMedia v2.0
DFX 5.1.1 Skin
Appstore Link
My RideRunner Plugins
RRMedia
RRExtended
DFXVoice
nope that doesn't work in my ExecTBL
james
