Results 1 to 8 of 8
Thread: Define code help
    Wants to make it harder monkeyracer's Avatar
    May 2007
    Lakehood, CO
    Define code help
    I probably missed it in searching for "define" and "/define" and "define code"
    I'm trying to set a label with the /DEFINE code, and it works, but if I want to define more than one label in the same code, it doesn't work...
    Code:
    /DEFINE LABEL1 "TRACKTIME"
    works, but
    Code:
    /DEFINE LABEL1 "TRACKTIME||REMAININGTRACKTIME"
    or
    Code:
    /DEFINE LABEL1 "TRACKTIME|REMAININGTRACKTIME"
    or
    Code:
    /DEFINE LABEL1 "TRACKTIME++REMAININGTRACKTIME"
    or
    Code:
    /DEFINE LABEL1 "CUSTOMLABEL1"
    EXECTBL.ini -
    Code:
    "CUSTOMLABEL1","TRACKTIME||REMAININGTRACKTIME"
    or
    Code:
    /DEFINE LABEL1 "$CUSTOMLABEL1$"
    EXECTBL.ini -
    Code:
    or
    Code:
    /DEFINE LABEL1 $CUSTOMLABEL1$
    EXECTBL.ini -
    Code:
    or
    Code:
    /DEFINE LABEL1 "#CUSTOMLABEL1#"
    EXECTBL.ini -
    Code:
    or
    Code:
    /DEFINE LABEL1 #CUSTOMLABEL1#
    EXECTBL.ini -
    Code:
    none of those work.
    What do I need to do to set a string of labels in one define code? (In what I want, sometimes there is one label in that line, sometimes there are 4, which is why i'm using the define code.)
    2007 Chrysler PT Cruiser TE
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
    Favorite thread EVER!
    May 2007
    Lakehood, CO
    Basically I just need to know how to refer to the double pipes in a /DEFINE code...
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    I think you need to start with a= sign.
    "CUSTOMLABEL1","=TRACKTIME||= - REMAININGTRACKTIME"
    May 2007
    Lakehood, CO
    That just displays like this:
    TRACKTIME - REMAININGTRACKTIME
    rather than the actual times... I think I might have a solution sort of. it's a little more work, but I'll post my findings later.
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Just tryed this and it shows the values.
    May 2007
    Lakehood, CO
    Ok, so what I ended up doing was defining each item seperately, something like this:
    in mylabels.txt
    Code:
    /DEFINE LABEL1 TRACKTIME||
    /DEFINE LABEL2 = / ||
    /DEFINE LABEL3 REMAININGTRACKTIME||
    Then on the button:
    Code:
    "WRITETOFILE;labels.txt;=/DEFINE MYLABELS #LABEL1##LABEL2##LABEL3#"
    With the label as
    Code:
    L01,,,,,,,,#MYLABELS#
    So I have two seperate .txt files, one that stays the same (mylabels.txt), and one that changes based on the button press (labels.txt).
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    What may I ask are you using that for or trying to do by using such a button?
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    May 2007
    Lakehood, CO
    well, since you ask, here's what I'm actually doing with this:
    from my exectbl.ini:
    Code:
    "MAININFO","WRITETOFILE;$skinpath$maininfo.txt;=/DEFINE MAINLABEL GPSINFO||ADDTOFILE;$skinpath$maininfo.txt;=/DEFINE ROW1 "TAGARTIST"||ADDTOFILE;$skinpath$maininfo.txt;=/DEFINE ROW2 "TAGALBUM"||ADDTOFILE;$skinpath$maininfo.txt;=/DEFINE ROW3 "TAGTITLE"||ADDTOFILE;$skinpath$maininfo.txt;=END||RELOADSKIN"
    "GPSINFO","WRITETOFILE;$skinpath$maininfo.txt;=/DEFINE MAINLABEL TRACKINFO||ADDTOFILE;$skinpath$maininfo.txt;=/DEFINE ROW1 "#ROW2A##ROW2B##ROW2C##ROW2D##ROW2E##ROW2F#"||ADDTOFILE;$skinpath$maininfo.txt;=/DEFINE ROW2 "#ROW3A##ROW3B##ROW3E##ROW3F##ROW2L#"||ADDTOFILE;$skinpath$maininfo.txt;=/DEFINE ROW3 "#ROW3C##ROW3D##ROW3G##ROW3H##ROW2L#"||ADDTOFILE;$skinpath$maininfo.txt;=END||RELOADSKIN"
    "TRACKINFO","WRITETOFILE;$skinpath$maininfo.txt;=/DEFINE MAINLABEL MAININFO||ADDTOFILE;$skinpath$maininfo.txt;=/DEFINE ROW1 "#ROW1A##ROW1B##ROW1C#"||ADDTOFILE;$skinpath$maininfo.txt;=/DEFINE ROW2 "#ROW2G##ROW2H##ROW2I##ROW2J##ROW2K#"||ADDTOFILE;$skinpath$maininfo.txt;=/DEFINE ROW3 "#ROW3I##ROW3J##ROW3K##ROW3L##ROW3M##ROW3N#"||ADDTOFILE;$skinpath$maininfo.txt;=END||RELOADSKIN"
    maininfo.txt: (after pressing the button while trackinfo is displayed)
    Code:
    END
    moreinfo.txt: (doesn't change, there's no writetofile pointing to this one)
    Code:
    /DEFINE ROW2A =city - ||
    /DEFINE ROW2B CURRENTCITY||
    /DEFINE ROW2C = / zip - ||
    /DEFINE ROW2D CURRENTZIP||
    /DEFINE ROW2E = / sats - ||
    /DEFINE ROW2F GPSSAT||
    /DEFINE ROW2L =","LEFT
    /DEFINE ROW3A =lat - ||
    /DEFINE ROW3B GPSLAT||
    /DEFINE ROW3C =lon - ||
    /DEFINE ROW3D GPSLON||
    /DEFINE ROW3E = / alt - ||
    /DEFINE ROW3F GPSALT||
    /DEFINE ROW3G = / hdg - ||
    /DEFINE ROW3H GPSHDG
    /DEFINE ROW1A CURRENTTRACKTIME||
    /DEFINE ROW1B = / ||
    /DEFINE ROW1C TRACKTIME||
    /DEFINE ROW2G TAGGENRE||
    /DEFINE ROW2H = / ||
    /DEFINE ROW2I TAGYEAR||
    /DEFINE ROW2J = / ||
    /DEFINE ROW2K KBPS||
    /DEFINE ROW3I =cpu - ||
    /DEFINE ROW3J CPU||
    end
    relevant sections of main.skin:
    Code:
    RoadRunner Skin
    RRScreen mAv1c
    /, INC, FILENAME
    INC,maininfo.txt
    INC,moreinfo.txt
    INC,color.txt
    /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
    L02,130,381,530,30,#FRed#,#FGreen#,#FBlue#,22,"BankGothic Md BT",#ROW3#,"CENTER"
    L02,132,383,530,30,0,0,0,22,"BankGothic Md BT",#ROW3#,"CENTER"
    L03,130,352,530,30,#FRed#,#FGreen#,#FBlue#,22,"BankGothic Md BT",#ROW2#,"CENTER"
    L03,132,354,530,30,0,0,0,22,"BankGothic Md BT",#ROW2#,"CENTER"
    L04,130,322,530,30,#FRed#,#FGreen#,#FBlue#,22,"BankGothic Md BT",#ROW1#,"CENTER"
    L04,132,324,530,30,0,0,0,22,"BankGothic Md BT",#ROW1#,"CENTER"
    L005,127,323,537,89,,,,,,"EXEC;#MAINLABEL#||=",
    So, basically, I have three lines on my skin that normally display tagtitle, tagartist and tagalbum. By pressing the labels (L005,127,323,537,89,,,,,,"EXEC;#MAINLABEL#||=",) it toggles between three displays. all three can be viewed in these screen shots:
    This one shows the first set of labels:
    This one shows the second set of labels:
    And the third set, with a switchable flash speedo:
    I was trying to keep the question simple, so I didn't get lost in trying to explain the complexities of it.
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
  1. GPS/MapPoint VB Source Code
    By stevieg in forum Software & Software Development
    Last Post: 01-28-2011, 04:59 PM
  2. Weird Registration Code and Hardware Code problem
    By lookinco in forum StreetDeck
    Last Post: 09-30-2006, 03:25 AM
  3. Replies: 0
    Last Post: 06-11-2006, 06:49 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
  5. FP Feature Requests
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-15-2004, 02:19 PM
