Page 10 of 10 FirstFirst 12345678910
Results 91 to 94 of 94
Thread: XM Radio - COMPLETE REWRITE
  1. #91
    Sep 2006
    XMD1000 issues
    I hear the preview channel when I am not in RR or if I do not select the XM Radio Button.
    The XM screen does not have any control over changing channel.
    I made my own cable for the XMD1000 using the instructions. I have a lot of experience builing cables, used to do it for a living, but still can make mistakes so I checked it 10 times.
    It obviously provides power correctly but I can't see any data if I try to look at it with hyperterm.
    Any direction would be appreciated.
    Jerry
  2. #92
    Sep 2006
    Found it!
    It turns out it was a solder bridge. My old eyes are starting to fail me.
    I guess the only problem with being perfect is you hate to admit when you make a misake.
    Jerry
  3. #93
    Constant Bitrate FockMasterDan's Avatar
    May 2008
    Westerville, Ohio
    Quote Originally Posted by dhantiflag View Post
    i was thinking bout buy XM too, having both.... but im not that much of a "baller" yet hehehe...
    Don't buy both, supposedly after the merger we'll get all the channels with each service.
    Mitch could you send me that code (just for on with the computer) and which pin on the parallel port will the signal be on, and out of curiosity could I use multiple signals that trigger with different applications? I don't know my exact use with this, but in theory I could wire all the different hardware to only trigger when I need it just to save power and not run devices unnecessarily.
    Computer is in the car, but in a very "raw" install right now.
    Worklog - here
  4. #94
    MySQL Error
    Oct 2004
    fockmasterdan, you know its in the RR build
    i also posted a command line version too
    the one problem i see, is the UNDEFINED state of the pins when the PC is not under OS controll (ie booting)
    u can email me, and ill send u the test prog
    as for XM sirius, i dont think there will be ANY new HW for 2008, maybe not till late 2009
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  1. anything wrong with hooking up xm AND radio to same line-in?
    By Sonicxtacy02 in forum General Hardware Discussion
    Last Post: 01-22-2008, 08:04 PM
  2. Got XM to work, then it took a dump
    By DuDs in forum StreetDeck
    Last Post: 05-06-2006, 06:42 PM
  3. XM Satellite Radio to Unveil XM Advanced Services at 2006 Consumer
    By Will Albers in forum General MP3Car Discussion
    Last Post: 03-27-2006, 09:49 PM
  4. need a 3 foot xm radio antenna extension
    By n8scstm in forum General MP3Car Discussion
    Last Post: 01-23-2006, 11:18 PM
  5. Newbie's guide
    By EBFoxbat in forum Newbie
    Last Post: 02-08-2005, 11:06 AM
