Results 1 to 7 of 7
Thread: AlbumArt and flash
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    AlbumArt and flash
    i been trying to get this to work and cant find the way, i created a small flash object using flash CS3 to show the current albumart with some effects, it works flawlessly standalone, hardcoding the picture path, but when using RR it just dont work, it appears that the flash object is not getting the path from RR for the image, i even make the flash object to set a variable in RR to see what is getting from _root.ALBUMART and all i get is "undefined". i have the label "ALBUMART" in the screen where the movie is embedded, so as far as i know is all i need, heres part of the code i'm using
    Code:
    fscommand("GETLABEL", "ALBUMART");
    artwork = _root.ALBUMART
    fscommand("SETVAR;FLASH;" + artwork);
    Wants to make it harder monkeyracer's Avatar
    May 2007
    Lakehood, CO
    I'm not sure it will work with flash, but have you tried the RRStrings plugin yet with the "PathFromPath" tag?
    That might work.
    Or have you tried the "COVERART" code instead of albumart? coverart is supposed to act a little different than albumart.
    2007 Chrysler PT Cruiser TE
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
    Favorite thread EVER!
    EL CAMINO's Avatar
    Jul 2005
    that plugin will help if you don't want to use a script to get paths, i can do that inside flash or a script, the labels and indicators for 'ALBUMART" and "COVERART" will return a string with the path of each one as fas as i know...
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    i'm not using flash cs3 but if it helps i can post a working version from swishmax? Has no affects tho just displays the album art from the ALBUMART label.
    Live mp3Car Facebook Chat
    EL CAMINO's Avatar
    Jul 2005
    please thanx
    Woodbridge, VA
    Blog Entries
    32
    Quote Originally Posted by EL CAMINO View Post
    please thanx
    here you go.. you should be able to compile that , add the ALBUMART label and flash object to your skin file and be good to go. Credit goes to CDR for most of that code though.
    Attached Files Attached Files
    EL CAMINO's Avatar
    Jul 2005
    cool thanx again
  1. ALBUMART of the specified item
    By banderas in forum RR Skins
    Last Post: 04-09-2008, 11:57 AM
  2. Flash ALBUMART Loader
    By LeeVD in forum RR Skins
    Last Post: 01-10-2008, 04:14 PM
  3. Notice :- Flash speed with albumart
    By CdRsKuLL in forum RR Skins
    Last Post: 03-15-2007, 07:39 AM
  4. Audio_Browser and Albumart
    By CdRsKuLL in forum RR Bug Tracker
    Last Post: 03-12-2006, 03:48 PM
