Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: those with non transflexive screen...
    Dec 2007
    how do guys use it? i bought a used q1 umpc and it's almost impossible to see when there is no shade during day time. Is there a way to enhance visibility? Any thoughts would be great.. Thanks...
    Mar 2006
    Colorado, but Canadian!
    You use a skin that is bright. A black skin = mirror, while a white skin = readable.
    That and if it turns into a mirror, you know where the buttons are because they attract fingerprints like none other and like your remote for your tv, you should know where the buttons are on the screen. Also if you clean the screen to get little bit of dust and finger oil off, it becomes very readable for a while until the dust comes back.
    1.9in x 2.9in -- 47mm x 73mm
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    If you aim your screen towards the cieling of your car it will not reflect as much as if aimed straight back towards your rear window.
    The cieling of your car is all one color and has no light coming from it so I have found that putting my screen on an angle helps dramatically. Your screwed with a convertible.
    New Age Garmin - Skin for RR
    Mar 2006
    Quote Originally Posted by ThunderStick View Post
    or with a sunroof like most people have todays. I dont think I have been in a car without a sunroof as long as I can remember
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    2008 lilliput 629 with the LED backlight made all my sunlight issues go away.
    Live mp3Car Facebook Chat
    Variable Bitrate rijk's Avatar
    Feb 2007
    netherlands
    Sunroof does effect it a bit, but most trouble comes from the morning sun that shines threw the rear window. I have my screen mouned slightly deepend an not high up in the car. Found out with the normal radio that was a better posittion.
    Cartft have now got this product (anti-glare foil), when i need something of them, i will try this one out.
    May 2006
    Calgary, Alberta
    I had my Xenarc for a year and just lived without being able to see it in the daytime at al. Then one day I fished out the infrared receiver from behind the dash, looked through the menu options using the remote and found the brightness setting. Once I turned the brightness up to maximum, I had no issues with daytime viewing since.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    FLAC Griff1's Avatar
    Nov 2005
    Midlands
    I run my Lilli with the brightness up full too.
    What's this about new Lilli's having an led backlight??
    P4 2.8 HT, 512Mb Ram, 60Gb 2.5 HD, M4-ATX, SB Audigy2, BU353, Lilliput TS,Soundgraph Imon VFD,SONY Optiarc dvd Burner,RideRunner, iGo8, Custom Freedom 2.1
    Sep 2007
    West Springfield, MA
    The LED backlight is twice as bright.
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by blackcobra487 View Post
    going from the 8" "old" lilli (which was always brighter than the 7" lillis as proven at a couple meets) from the 2008 lilli was really night and day for me. I dunno if they're TWICE as bright ... but the difference is all too noticible. I cant confirm this but i also believe they're using a different touch screen because at no poitn in the last 6 months has my screen exhibited the "mirror" effect where there's nothing but sun
  1. Replies: 14
    Last Post: 09-11-2008, 04:14 PM
  2. Constantly removing the screen 7" lilliput advice
    By steveb in forum LCD/Display
    Last Post: 04-17-2007, 11:56 AM
  3. Cracked Touch Screen!
    By bmather9 in forum LCD/Display
    Last Post: 04-17-2007, 05:31 AM
  4. Is a transflexive touch screen worth it?
    By fatejd in forum LCD/Display
    Last Post: 03-16-2007, 11:35 AM
  5. Replies: 4
    Last Post: 01-26-2006, 03:35 AM
