Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: mpc with rr...
  1. #21
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Well, you gotta make a skin for it first to utilize the commands listed in the thread and change the "VIDEO" command, but yeah, it works like its supposed to.
    Like with most plugins, gotta skin it.
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
  2. #22
    May 2006
    Calgary, Alberta
    Quote Originally Posted by Sal R. View Post
    What do you mean skin it? I'm running Carwings Dynamic, what would I need to do besides installing the plugin?
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
  3. #23
    Aug 2006
    Sun Diego
    Quote Originally Posted by Maheriano View Post
    Create a button to run the exe.
    i.e.
    BXX,...,"RRVLC",""
    ExecTBL.ini
    "RRVLC","LOAD;RRLVC.skin;RUN;<pathtorrvlc.exe>\rrv lc.exe;rrvlc.exe
    RRVLC.skin has button codes to play, ffwd, frwd, etc.
    Have to create a skin for it.
  4. #24
    Dec 2007
    and if you wanna use different player, might wanna consider this alternative as well..
    http://www.mp3car.com/vbulletin/road...coverjuke.html
    That will play everything you throw at as well.. He did a great job making the whole thing integrated into rr apearancewise..
  5. #25
    Jan 2006
    Dublin, Ireland
    Hi Brandensin
    I have generic DVB-T USB Dongle (unsupported by native RR) which works perfectly in VLC by having each TV Station individually in an xspf Playlist file. Given that it's several years on from this thread and maybe the RRVLC plugin is better than it was, if you were in my position, would you go with your method or go with the RRVLC plugin to run your VLC Playlist ? Will the plugin only play AVI's or will it do anything that VLC will do on it's own ?
    C
  6. #26
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    His last post was 10-7-2009 so you likely won't get a response... buy hey, you never know. I don't have a suggestion to your question but maybe someone else will chime in on this.
  7. #27
    Jan 2006
    Dublin, Ireland
    It's OK, I read through the VLC Plugin thread and found details in posts #100 and #104 that VLC support is now embedded within RR.
    Therefore, all I needed to do was to run the RRCONFIG, set Video to use VLC, set the correct path to my Playlist files and then add .xspf to the list of file types supported. I originally had a single playlist with all TV stations (like the one listed below) but I could not simply jump from one station to another so I then just made a separate file for each TV station and so was able to then use the |<< and the >>| buttons on my screen to jump between stations.
    So, in short, you do NOT need to buy specific DVB-T USB Dongles.
    Code:
    <?xml version="1.0" encoding="UTF-8"?>
    <playlist xmlns="http://xspf.org/ns/0/" xmlns:vlc="http://www.videolan.org/vlc/playlist/ns/0/" version="1">
    	<title>Saorview Playlist</title>
    	<trackList>
    		<track>
    			<title>RTE 1</title>
    			<location>dvb-t://</location>
    			<duration>2700000</duration>
    			<extension application="http://www.videolan.org/vlc/playlist/0">
    				<vlc:id>0</vlc:id>
    				<vlc:option>dvb-frequency=546000000</vlc:option>
    				<vlc:option>dvb-bandwidth=8</vlc:option>
    				<vlc:option>program=1101</vlc:option>
    			</extension>
    		</track>
    		<track>
    			<title>RTE 2</title>
    				<vlc:id>1</vlc:id>
    				<vlc:option>program=1102</vlc:option>
    			</extension>
    		</track>
    		<track>
    			<title>TV 3</title>
    				<vlc:id>2</vlc:id>
    				<vlc:option>program=1103</vlc:option>
    			</extension>
    		</track>
    		<track>
    			<title>TG 4</title>
    				<vlc:id>3</vlc:id>
    				<vlc:option>program=1104</vlc:option>
    			</extension>
    		</track>
    		<track>
    			<title>RTE NEWS NOW</title>
    				<vlc:id>4</vlc:id>
    				<vlc:option>program=1105</vlc:option>
    			</extension>
    		</track>
    		<track>
    			<title>3 e</title>
    				<vlc:id>5</vlc:id>
    				<vlc:option>program=1106</vlc:option>
    			</extension>
    		</track>
    		<track>
    			<title>RTE Junior</title>
    				<vlc:id>6</vlc:id>
    				<vlc:option>program=1107</vlc:option>
    			</extension>
    		</track>
    		<track><title>RTE one + 1</title>
    				<vlc:id>7</vlc:id>
    				<vlc:option>program=1108</vlc:option>
    			</extension>
    		</track>
    	</trackList>
    </playlist>
  8. #28
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    Thanks for the follow up post, that will help others in the future.
  1. REQUEST: Run Multiple RR instances
    By Jarrod in forum Road Runner
    Last Post: 12-21-2008, 08:54 AM
  2. Auto Play DVD with MPC
    By Kurack in forum Road Runner
    Last Post: 03-09-2008, 07:20 PM
  3. Girder stops working when RR is launched
    By BlackStealth in forum Road Runner
    Last Post: 09-07-2006, 08:35 PM
  4. RR Interchange - Update RR via a USB Media Stick
    By Gobby in forum Road Runner
    Last Post: 10-04-2005, 05:48 PM
  5. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 01:22 PM
