Results 1 to 5 of 5
Thread: how to change rr label from sdk?
    Constant Bitrate spidermunz's Avatar
    Dec 2006
    italy, sardinia
    hi to all
    somebody know how to change one label of roadrunner using the sdk?
    i need to change "FREQUENCE" label to reset it to a new number after i change the radio frequence from my exetended plugin
    i need to change it to complete my automatic af for silabs plugin
    i thank you all
    Dec 2006
    italy, sardinia
    up!
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    i'm not sure you can change a standard rr label /extension created label via sdk. What you can do is use the label to set a variable which u can modify and use.
    Live mp3Car Facebook Chat
    Dec 2006
    italy, sardinia
    i think so this trick, but it can't solve all my problems
    alternate way (and good way for my problems) is tune the radio but not using the "tune pad"
    some command to change the frequence directly
    like this "ChangeFreq;105,5"
    the use is similar as the radiopreset, but i can put into all the frequence i need and change it every time i need
    Woodbridge, VA
    Blog Entries
    55
    you can do that. this is a code that i'm using in my flash skin to acheive this:
    Code:
    SETVAR;FREQENTER;" add _root.FREQENTER add "||WRITETOFILE;$RRPATH$DTUNE.fm;=$FREQENTER$||WAITEXEC|FMPRESET;DTUNE
    its a little different in vb6 but it'll still work, basically u create a vb6 variable containing the frequency you wish to tune to, then set a RR variable with that vb6 variable. The next portion writes that frequency to a "temporary" fm preset. Then you run a wait exec to insure the file has been created before using it in the last command which simply loads the preset. Let me know if you need me to break it down further but it does work and has worked for me for some time. My skin just has a number pad where the user has the option of dialing a station directly and thats how i handle it.
  1. Lsx Void 3.0
    By liquid_smoke in forum RR Skins No Longer Supported
    Last Post: 12-11-2013, 04:05 AM
  2. Holux GPS Trouble
    By mangus580 in forum StreetDeck
    Last Post: 11-26-2007, 09:56 PM
  3. Replies: 3
    Last Post: 04-24-2006, 04:53 PM
  4. Can this be done
    By ashgrovered in forum Coders Corner
    Last Post: 04-05-2006, 12:50 AM
  5. Freedrive SDK in RR label
    By LagunaICE in forum Road Runner
    Last Post: 11-12-2005, 02:24 PM
