Results 11 to 20 of 25
Thread: Smoothing things out
  1. #11
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Transparent as in you can put it on top of the skin in a defined area, and set the level of transparency for it.
    Here are a couple screen caps, one covering the top of the skin, one with it on top of album art. The nice part is you can click through the transparent visu's, so it can be placed on top of buttons ect.
    if iGuidance is not closing when RR closes, it sounds like it is not embedded correctly in some way. Winamp is another problem though! The next Version of the DFX skin will make sure Winamp is KILLED when RR closes As you can tell I have had this issue myself!
    My Fiero Build Thread
  2. #12
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    Quote Originally Posted by scythe000 View Post
    Now, the main problem I notice is that Winamp or iGuidance don't always seem to close when I exit RR. So, when I go back into RR, my GPS won't connect, or winamp acts weird. A reboot always fixes it, or even manually killing the processes. Is there some kind of auto-kill-on-exit script out there?
    This should point you in the right direction: http://www.mp3car.com/vbulletin/road...n-rr-exit.html
  3. #13
    May 2008
    Wow, I gotta say, this forum is fantastic. No flaming, no GTFO n00b! Thanks for the detailed and quick responses!
  4. #14
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    sure it is, just go ahead and ask about the whitebox or even better, the red ball, and you'll see....
  5. #15
    Jun 2007
    Depends on the day, sometimes all you'll get is "SEARCH!!!!".
  6. #16
    May 2008
    LOL, well the FAQ is the first thing I read, then I hit up search. Sometimes wording is obscure, then I post new. The next Thing I'm doing tonight is embedding my AT&T Connection Manager for my cellular card. Might be cool to try and script it out so, as soon as a signal is available, it connects. Would have made it a hell of a lot easier if AT&T had implemented it in it's own prog.
  7. #17
    May 2008
    Ok, here's my current set of things:
    1. I'm using a Xenarc 700TSV. It seems that on RR load, it drops it's brightness, and brightens back up on exit. RR setting changing this? It seems it's not the Xenarc.
    2. I've embedded AT&T's Connection Manager in RR. When I run it, the prog hangs b/c RR tries to stretch it to fit the app window. Can I tell RR not to resize?
    3. Is there an option to minimize RR? Maybe reskin the hibernate button to minimize instead.
    TIA!
    BTW, using DFX 3.0 skin.
  8. #18
    Jun 2007
    That's RR doing that. You need to edit the gamma settings in RRconfig. It's handy if you need a brightness reduction at night.
    Tap the upper right hand corner from the main menu. It's in the DFX help file by the way.
  9. #19
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    i can answer 2 of those Q?
    brightness gamma settings in rr config
    minamise in the skin cmds "MINIMIZE" - Minimizes Road Runner into the taskbar
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  10. #20
    May 2008
    You guys are the best! I'm going to try to setup my AT&T card to use dial-up networking, so maybe I won't have to mess with the embedded app at all.
  1. Wild Things PSone LCD to PC
    By godzi11a in forum LCD/Display
    Last Post: 11-22-2005, 08:13 PM
  2. Am I wiring things correctly??
    By skidogg77 in forum LCD/Display
    Last Post: 02-22-2005, 09:03 PM
  3. Things I have
    By GHOSTWHISPER in forum Newbie
    Last Post: 12-31-2004, 10:33 AM
  4. Rage against some stupid things
    By kraft in forum Off Topic
    Last Post: 11-07-2004, 05:29 PM
  5. Nice to see things operational again :-)
    By sproggy in forum General Hardware Discussion
    Last Post: 02-18-2000, 07:51 PM
