Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
Thread: Smoothing things out
  1. #21
    May 2008
    Damn. If I use DUN for the AT&T app, it won't let me use HSDPA (3G). Now I'm back to needing the AT&T app working.
  2. #22
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    What are you using to connect to the internet? (hardware wise)
  3. #23
    May 2008
    Option GT Ultra. I had to dig around quite a bit, but apparently one needs to add the following init string to the modem for it to accept a DUN request: AT+CGDCONT=1,"IP","isp.cingular" or if that doesn't work: "AT+CFUN=1;+CGDCONT=1,"IP","isp.cingular"
    Then one creates a DUN connection with no username or password, and a # of *99***1#
    both of those init strings generate a 692 error (hardware failure). I can connect just fine using the AT&T Connection Manager, but ideally, I'd like to set it up to auto-connect when requested, and still be able to use 3G, which apparently is not possible with a DUN Connection.
  4. #24
    May 2008
    Apparently Sony is releasing a USB GSM card with a built in GPS receiver! It's supposed to come out in september. This'd be a nice option to combine 2 usb ports into 1 unit.
  5. #25
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by scythe000 View Post
    It uses the same chipset as all those units. There is even a guy on here somewhere building one using the generic chip. The chip alone is over $100...
    1.9in x 2.9in -- 47mm x 73mm
  1. Wild Things PSone LCD to PC
    By godzi11a in forum LCD/Display
    Last Post: 11-22-2005, 08:13 PM
  2. Am I wiring things correctly??
    By skidogg77 in forum LCD/Display
    Last Post: 02-22-2005, 09:03 PM
  3. Things I have
    By GHOSTWHISPER in forum Newbie
    Last Post: 12-31-2004, 10:33 AM
  4. Rage against some stupid things
    By kraft in forum Off Topic
    Last Post: 11-07-2004, 05:29 PM
  5. Nice to see things operational again :-)
    By sproggy in forum General Hardware Discussion
    Last Post: 02-18-2000, 07:51 PM
