Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 36
Thread: Getting an error when trying to open rr for the first time
  1. #11
    Nov 2007
    Chesapeake
    Done that, I now get this error " Run-time error '75': Path/File access error" when trying to open the config.exe. After clicking OK, it opens the config.exe and I can change stuff around. After saving changes and setting the skins to BMV2. I try and open the RR.exe and get the error that state "C:\Program Files\Road Runner\SKINS\ Alpine does not contain a valid skin! Check you settings and try again." Well the Config setting is set to BMV2 so I don't know where Alpine is coming from. Any idea of what is going on and how fix it?
  2. #12
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by 02rsxs06 View Post
    Goodness! you got problems! Attach your rr.ini file let's take a look.
  3. #13
    Nov 2007
    Chesapeake
    Not to be stupid but where in the Road Runner folder would I find the ini?
  4. #14
    Dec 2007
    i heard people having all sort of problem using rr with vista... why not run xp, saves you trouble now and later... those file access problem seems alot to do with the way vista works... I was thinking about vista too,but what's the point if i am gonna run rr most of the time... This is not a solution but, i strongly suggest you do this with xp like creator recommended.. You might encounter more problems later and evetually fed up with it...
    ini is in the road runner root directory where it was installed...
    rr.ini
  5. #15
    Nov 2007
    Chesapeake
    Ok, thank you.
    Here is my ini file. I didn't realize RR had so many problems running on Vista.
    [Player Setup]
    player=Winamp
    winamppath=Click here to set path
    hidewinamp=true
    exitmute=true
    [General]
    voice=false
    disableinternat=false
    showicons=false
    showextensions=false
    hidemouse=false
    hidetaskbar=false
    hidedesktop=false
    hidedots=false
    gpstime=false
    exitmode=0
    dateformat=Short Date
    timeformat=Short Time
    locale=0
    screentype=4:3
    debugmode=false
    enableclipping=true
    nozoom=false
    usegestures=true
    leavemousealone=false
    closeapps=false
    fastmode=-1
    usedualmon=false
    soundcard=0
    screenlimit=10
    mastervolmap=-1
    hibernateaware=true
    forcehibernate=false
    hibernatereload=true
    usbsound=false
    browsertype=0
    usevoicecontrol=false
    usecar2pc=false
    fadeinvolume=true
    picspath=To set path, Click --->
    [Skins]
    skinpath=C:\Program Files\Road Runner\Skins\BMV2\
    nightskin=C:\Program Files\Road Runner\Skins\BMV2\
    transition=-1
    background=To set path, Click --->
    TransitionTime=0.2
    [Gamma]
    gammamode=3
    gpsgammamodeoffset=0
    gammaday=0:0:0
    gammanight=-50:-50:-50
    gammadaytime=1:00
    gammanighttime=1:00
    autogammamode=1
    autoskinmode=1
    [Preload Screens]
    [Music]
    musicpath=Click here to set path
    playlistpath=Click here to set path
    useid3=0
    singleclickaudio=false
    noformat=false
    listnumbers=true
    listfollowssong=true
    id3listformat=%title%
    id3browseformat=%title%
    titlesafter=-
    albumart=*.txt
    fadeimages=false
    visuname=MilkDrop
    scrollmode=1
    circularlist=false
    groupnumbers=false
    resumemusic=0
    audiorepeat=false
    audioshuffle=false
    transparentvisu=false
    opacityvisu=40
    [Radio]
    radiomode=0
    allowallfreqs=false
    userbds=false
    [XM]
    xmport=0
    xmlineinplugin=false
    xmtype=0
    singleclickxm=false
    xmformat=%station% %artist%
    [SIRIUS]
    srport=0
    srlineinplugin=false
    singleclicksr=false
    srformat=%station% %artist%
    [Video]
    videopath=Click here to set path
    mpcpath=Click here to set path
    videoautohide=true
    videohidetime=4
    builtinvideo=true
    videoshuffle=false
    [TV]
    tvline=0
    [GPS]
    mapmonkeypath=Click here to set path
    gpspath=Click here to set path
    gpsname=
    overspeed=55
    gpsport=0
    mappointmap=1
    mapcountry=United States
    mapcity=
    mapautozoom=true
    isunits=true
    usegpsserv=false
    gasfinderautorefresh=false
    [IG Native]
    [Speed Att Vol]
    speedatt=false
    [Phidget]
    phidget1=0
    phidget2=0
    phidget3=0
    phidget4=0
    phidget5=0
    phidget6=0
    phidget7=0
    phidget8=0
    [4 Temps]
    tcomport=
    tempscale=c
    temp1=c
    temp2=c
    temp3=c
    temp4=c
    [Volt Meter]
    vcomport=
    [Phone]
    phoconodesign=false
    motophone=false
    phonelistspath=Click here to set path
    contactspicturespath=Click here to set path
    ringtone=Click here to set path
    smstone=Click here to set path
    maxcalllistentries=100
    phoconoincallevent=false
    connecthsp=true
    standardphonebook=0
    phonebooksencoding=windows-1252
    [Weather]
    cityweather=
    weatherunits=USA
    weatherdegress=º
    localdatacaptureinterval=0
    [Extra's]
  6. #16
    Jun 2008
    Im haveing the same Line-1 issue. If i goto the program file and click on the exe file it says "canot access the specific device path or file you may not have the aproperate permission to acces them.
    Im running windows xp service pack 2
  7. #17
    May 2006
    Calgary, Alberta
    I don't know why anyone would want to run a carputer on an operating system that uses 750 megabytes or more just to boot.
    But to help you out a little, I was able to download and install RoadRunner on my 32 bit Vista laptop no problem. It runs fine. I got the same skin not found error that you're getting but that's easily solved by running the config file.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
  8. #18
    Jun 2008
    that doesnt help me much
  9. #19
    Sep 2006
    War-Town, GA.
    Ok, thank you.
    [Extra's]
    Don't see anything obviously wrong - I'm baffled! The last think i can think of is that i read somewhere that Vista users have to run RR in compatibility mode and don't use the Euro Glass theme or something like that.
    Maybe somebody else can help.
  10. #20
    Nov 2007
    Chesapeake
    OK, I guess the best solution is to go back to XP.
  1. RR hibernate time window length for command execution
    By Iceman_jkh in forum Road Runner
    Last Post: 02-06-2008, 06:57 AM
  2. problems with navigation in streetdeck
    By customaudioman in forum StreetDeck
    Last Post: 01-25-2008, 01:46 PM
  3. Real Time RR Cmd Debug Window
    By Blue ZX3 in forum RR Skins
    Last Post: 01-20-2008, 08:55 AM
  4. Comport 5 is not acessable with RR open
    By Cruelkix in forum Road Runner
    Last Post: 09-12-2006, 01:33 AM
  5. IE in RR bug
    By accentsound in forum RR Bug Tracker
    Last Post: 07-10-2005, 02:21 PM
