Results 1 to 10 of 17
Thread: Getting an error when trying to open rr for the first time
    Jun 2008
    ok I run Launch RRConfig. exe from the desk top. It runs fine. I click save and start RRR and Autolt Error pops up. It says "Line -1: Error: unable to execute the external program. Access is denied. I then click the Launch RoadRunner Short cut on the desk top an it says Windows cannot access...... I then goto C:\Program Files\Road Runner\RoadRunner.exe and it gives me the same error code. I was also running avg free when I sintalled it the first time. It saw RoadRunner.exe as virus I sins removed and reinstalled Road Runner with avg off still with no luck
    Windows XP service pack 2
    Mar 2006
    Colorado, but Canadian!
    If your crappy virus program deleted RR.exe from the archive, then it wont work. Can you verify the exe is there in the program folder where it is supposed to be?
    Also you should always run RRConfig from RR's root folder.
    1.9in x 2.9in -- 47mm x 73mm
    Mar 2006
    Also make sure to turn off heuristic scanning with your avg program.
    Jun 2008
    C:\Program Files\Road Runner\RoadRunner.exe Is there. I did notice that roadrunner.exe doesn't have a graffics icon like RRConfig.exe does. Ive uninstalled and reinstalled RR with the virus program completely off. I still have the same systems.
    Jun 2008
    I removed avg then removed RR i then went to the program files and deleted the RR folder. I then reinstalled RR. I still have the same issue nothing has changed.
    Jun 2008
    RR Config if that helps
    [Player Setup]
    player=Winamp
    inipath=C:\Program Files\Road Runner\
    winamppath=C:\Program Files\Winamp\
    hidewinamp=false
    exitmute=true
    [General]
    launchpath=C:\Program Files\Road Runner\launch\
    voice=false
    disableinternat=false
    showicons=false
    showextensions=false
    hidemouse=false
    hidetaskbar=false
    hidedesktop=false
    hidedots=false
    gpstime=false
    exitmode=0
    dateformat=Short Date
    timeformat=Short Time
    locale=0
    screentype=4:3
    debugmode=false
    enableclipping=true
    nozoom=false
    usegestures=true
    leavemousealone=false
    closeapps=false
    fastmode=-1
    usedualmon=false
    soundcard=0
    screenlimit=10
    mastervolmap=0
    hibernateaware=true
    forcehibernate=false
    hibernatereload=true
    usbsound=false
    browsertype=0
    usevoicecontrol=false
    usecar2pc=false
    fadeinvolume=true
    picspath=To set path, Click --->
    [Skins]
    skinpath=C:\Program Files\Road Runner\Skins\BMV2\
    nightskin=C:\Program Files\Road Runner\Skins\BMV2\
    transition=-1
    background=To set path, Click --->
    TransitionTime=0.2
    [Gamma]
    gammamode=3
    gpsgammamodeoffset=0
    gammaday=0:0:0
    gammanight=-50:-50:-50
    gammadaytime=1:00
    gammanighttime=1:00
    autogammamode=1
    autoskinmode=1
    [Preload Screens]
    [Music]
    musicpath=E:\music\
    playlistpath=E:\music\
    useid3=0
    singleclickaudio=false
    noformat=false
    listnumbers=true
    listfollowssong=true
    id3listformat=%title%
    id3browseformat=%title%
    titlesafter=-
    albumart=*.txt
    fadeimages=false
    visuname=MilkDrop
    scrollmode=1
    circularlist=false
    groupnumbers=false
    resumemusic=0
    audiorepeat=false
    audioshuffle=false
    transparentvisu=false
    opacityvisu=40
    [Radio]
    radiomode=0
    allowallfreqs=false
    radioline=0
    userbds=false
    [XM]
    xmport=0
    xmline=0
    xmlineinplugin=false
    xmtype=0
    singleclickxm=false
    xmformat=%station% %artist%
    [SIRIUS]
    srport=0
    srline=0
    srlineinplugin=false
    singleclicksr=false
    srformat=%station% %artist%
    [Video]
    videopath=Click here to set path
    mpcpath=Click here to set path
    videoautohide=true
    videohidetime=4
    builtinvideo=true
    videoshuffle=false
    [TV]
    tvline=0
    [GPS]
    mapmonkeypath=Click here to set path
    gpspath=Click here to set path
    gpsname=
    overspeed=55
    gpsport=0
    mappointmap=1
    mapcountry=United States
    mapcity=
    mapautozoom=true
    isunits=true
    usegpsserv=false
    gasfinderautorefresh=false
    [IG Native]
    [Speed Att Vol]
    speedatt=false
    [Phidget]
    phidget1=0
    phidget2=0
    phidget3=0
    phidget4=0
    phidget5=0
    phidget6=0
    phidget7=0
    phidget8=0
    [4 Temps]
    tcomport=0
    tempscale=c
    temp1=c
    temp2=c
    temp3=c
    temp4=c
    [Volt Meter]
    vcomport=
    [Phone]
    phoconodesign=false
    motophone=false
    phonelistspath=Click here to set path
    contactspicturespath=Click here to set path
    ringtone=Click here to set path
    smstone=Click here to set path
    maxcalllistentries=100
    phoconoincallevent=false
    connecthsp=true
    standardphonebook=0
    phonebooksencoding=windows-1252
    [Weather]
    cityweather=
    weatherunits=USA
    weatherdegress=º
    localdatacaptureinterval=0
    [Extra's]
    Jun 2008
    Quote Originally Posted by THEREALRAWPWR View Post
    never get a real answer on this site. It's just one big circle jerk here. .........good luck.
    Im starting to see some truth in this post
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    first delete any RoadRunner.exe you might have in C:\Program Files\Road Runner\
    also if you see a resume.ini delete it as well(this will erased any resuming info)
    use the latest beta from the stickyand just copy RoadRunner.exe to your C:\Program Files\Road Runner\ folder. your problems are just to obvious.
    Mar 2006
    Do you have "RoadRunner" as the directory or "Road Runner"?
    Jun 2008
    EL CAMINO I fallowed your instructions and I still have the same issue. What do you think the problem might be?
    2k1Toaster The file containing RR is Road Runner with a space. The RR exe file is RoadRunner.exe with no space
  1. Replies: 35
    Last Post: 03-05-2009, 09:16 PM
  2. RR hibernate time window length for command execution
    By Iceman_jkh in forum Road Runner
    Last Post: 02-06-2008, 06:57 AM
  3. problems with navigation in streetdeck
    By customaudioman in forum StreetDeck
    Last Post: 01-25-2008, 01:46 PM
  4. Real Time RR Cmd Debug Window
    By Blue ZX3 in forum RR Skins
    Last Post: 01-20-2008, 08:55 AM
  5. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 01:22 PM
