Page 11 of 29 FirstFirst ... 23456789101112131415161718192021 ... LastLast
Results 101 to 110 of 281
Thread: MJSG RR - Public Release - NEW XM, Improved HD *7/18/08 - UPDATED*
  1. #101
    Jul 2006
    Mitch, yes I do realize that the 12-13 version is different from yours... I was just trying to see if it was a hardware issue or not. I hope I'm not coming across as complaining, I'm not... I really want this to work, as it's always been annoying to me to wait when switching between sources. Would not having the xm caching line in rr.ini cause it to lock up? I plan to try it tonight, just wanted to get your thoughts.
  2. #102
    MySQL Error
    Oct 2004
    ok, barnyard, we on SAME page then
    no, xmusecache would not lock app, nothing should look application at start up
    but if u logged!!! we might see something!!!
    debugmode=true
    xmdebug=true
    you're not using sirius also?, right?
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  3. #103
    Jul 2006
    Quote Originally Posted by mitchjs View Post
    debugmode=true
    xmdebug=true
    mitch
    There is only on line logged when I try the 7-8 version:
    7/8/2008 6:18:40 PM: Start -- Version: 7/7/2008
    When it hangs, if I cntrl+alt+del, and kill RR, fire up an old version (12-13 in this case) it'll fire right up, and XM works fine, surviving many hibernation/resumes.
    If I change xmport to 0, your 7-8 version will start, but obviously no XM.
    Correct, i don't have sirus.
    MSI K9N6GM
    1 gig RAM
    8" Lilliput
    Onstar GPS mod
    XM
    Visteon HDZ300
  4. #104
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    Sorry I'm not on the satellite radio bandwagon, but just wanted to report that Mitch's RR source has been running on my desktop now for over 15 hours, its been switched from mp3 to vid to hd multiple times, across many skins in my collection and has been 100% stable thus far.
    Nice work Mitch, its really nice to see someone to improve on the RR source code.
    Just a note I'm using mic in on my desktop and it works great, I assume you are just muting the HD hardware when switching menus?
  5. #105
    Jul 2006
    Thumbs up
    Ok a little update. I changed the following in my rr.ini (they were true):
    forcehibernate=false
    hibernatereload=false
    I disabled motionlock, and loaded your 7-1 version (same as 7-8 without the audio selector stuff)
    I added xmusecache=true
    It seemed to run fine all the way home. I manually hibernated, and resumed from each source (XM & HD) and it picked up right where it left off. I ended up setting the xmcache back to false because it didn't seem to want to re-populate the channels.... I can live with it not caching.
    A little snippet from my log:
    7/9/2008 5:46:24 PM: PrepareForHibernate: (Start)
    7/9/2008 5:46:24 PM: Enter Exec: False, radio_player.skin, "ONSUSPEND", False
    7/9/2008 5:46:24 PM: Que Exec: True, radio_player.skin, "ONSUSPEND", False
    7/9/2008 5:46:24 PM: Executing: ONSUSPEND
    7/9/2008 5:46:24 PM: Leave Exec: False, radio_player.skin, ONSUSPEND, False
    7/9/2008 5:46:24 PM: HD---> stopradio: HDRadioActive = false
    7/9/2008 5:46:24 PM: XM---> XMInActive: XMON=False
    7/9/2008 5:46:24 PM: XM---> XMSaveOut: xmcache.ini, XMCurrentTunedChannel=150
    7/9/2008 5:46:24 PM: XM---> XMSaveOut: End Sub
    7/9/2008 5:46:24 PM: HD---> HD Radio Station Name:Extreme HD Radio by CLEAR CHANNEL
    7/9/2008 5:46:26 PM: XM---> oXM_XMEventRadioPoweredOff:
    7/9/2008 5:46:26 PM: XM---> XMPowerOFF: XMON=False
    7/9/2008 5:46:26 PM: HD---> oHD_HDRadioEventCommError: Error= The port is closed.
    7/9/2008 5:46:26 PM: HD---> HDRadioPowerOff: frmCOM.oHD.Close (DTR Drop, HD Powered off...)
    7/9/2008 5:46:26 PM: PrepareForHibernate: (After radio power's)
    7/9/2008 5:46:26 PM: PrepareForHibernate: End Sub
    looks like it's terminating correctly now.
    So far so good!
    MSI K9N6GM
    1 gig RAM
    8" Lilliput
    Onstar GPS mod
    XM
    Visteon HDZ300
  6. #106
    MySQL Error
    Oct 2004
    GREAT!!
    switch to the 7/8 version please... there is many other "little" fixes
    specially with the xm tuning
    but xmusecache it works perfectly
    it doesnt "re-populate"...
    when you go into XM, all Cached channels should be visable instantly, the rest will load in over time
    (that is if u have a full cache, if you dont, it will create one...just need to wait for all channels to load)
    song data will load over time...the scanning of XM is cyclic, 1..2...3...4.. unlike Sirius... which is ondemand(better)
    please use it, if there is an issue, lets figure it out
    ***** XMCACHE.INI ***** must be WRITE ENABLED!!!!
    also... SOME FYI
    forcehibernate, this is used ONLY when RR does the hibernation, from a skin command...
    not when the pc is told to hibernate from an external action
    hibernatereload, this is used to tell the PLAYER(winamp) to reload the playlist from the file "winamp.m3u", not sure why this is needed nor what is actually does.... anyone know?
    so... is you're problem "motionlock"?
    it should look at if the system is going into hibernation, and shut the hell up
    btw, what is "motionlock"?
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  7. #107
    MySQL Error
    Oct 2004
    Quote Originally Posted by blk02si View Post
    well its a bit more then JUST muting the HD Hardware, but YES, i do mute the HD Hardware when HD Radio isnt ACTIVE
    thanks for your testing!
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  8. #108
    MySQL Error
    Oct 2004
    everyone testing... make sure if you got it in your RR.ini
    resumecheck=false
    its whole concept dont make sense to me, and lets keep it out of the picture on resuming... its some sort of workaround, to see if the pc resumed, but there is no safety check, and you could get into code that should only run once, run more the once
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  9. #109
    Jun 2003
    Memphis - TN
    Could I ask for a small request? Because some of us who use the Car2PC adapter, have problems, is it possible to setup a duplicate command? I know that RRnext/RRprev can be used to change not only winamps song change, but also Xms next/prev channels. Because of poor support w/ the car2PC adapter, I am forced to use the winamp plugin as well as the car2pc built in support together. This keeps me from being able to use my steering wheel controls to change songs, BUT if I had a duplicate command, I can map it to a different button on my headunit and be ble to change the songs.
    Could you duplicate the command w/ maybe XMnext and XMprev? If you want, I can test a version before you release it.
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
  10. #110
    MySQL Error
    Oct 2004
    custommx3, i dont understand...
    you want a command that ONLY changes, XM channels?
    i also dont really know how the car2pc adaptor fits into RR..
    its actions get translated into RR Skin commands?
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. RR 09-30-2007 ... HD Radio & some more..
    By guino in forum Road Runner
    Last Post: 10-20-2007, 10:01 PM
  2. XM issues with RR
    By dseoane in forum Road Runner
    Last Post: 08-10-2007, 06:10 AM
  3. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
