Ok, I'll try the 7-8 version tonight... Do I need to re-register the files?
Motionlock just disables any video/DVD from playing while the vehicle is moving.
****EDIT****
I tried the 7-8 version at lunch... same results as before. It hangs at "Starting Serial Devices..." I put the 7-1 exe back, and it fires right up. Is it because I don't have your audio selector? Do you need another "beta tester" for that?![]()
LinkBack URL
About LinkBacks
The car2PC.exe is compiled from the source code provided by indashpc.org. It seems the code is only avail for 1.0. Im using 1.7 winamp plugin. Really, you dont need the winamp plugin, and are supposed to use the car2pc.exe only. Unfortunately, due to a bug, this causes my LCD on my
