Page 7 of 29 FirstFirst 1234567891011121314151617 ... LastLast
Results 61 to 70 of 281
Thread: MJSG RR - Public Release - NEW XM, Improved HD *7/18/08 - UPDATED*
  1. #61
    Apr 2007
    Save your logs for Mitch.... I had the same kinds of issues until I wired my XM and HD to be on w/computer power supply. Ever since XM and HD have been perfect -- doesn't matter which was active when I hibernate. For whatever reason my setup doesn't fully come out of hibernate until I hit the touchscreen.... so I usually wait a bit
  2. #62
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    Quote Originally Posted by mitchjs View Post
    sonicx, logs..logs...logs
    I havent had xm or HD turn on ISSUE since this release
    need to see if xm was found...
    at this point i dont see any issues...
    it up to you guys to provide tangable(sp) data
    mitch
    well i cant duplicate that error now so i'll just let it go. Now couple of other things i have been able to duplicate. If i go from XM playing, back to the main menu, the run the RADIO command radio will successfully turn on and play, but if i go back to the main menu radio turns off and XM goes back to playing. Is it supposed to work this way?
    Another thing i've noticed is that your SAT and TER labels dont update after resume. If i restart road runner they start working again.
    here's my debug showing whats goin down with the XM switchback problem.
    Attached Files Attached Files
    Live mp3Car Facebook Chat
  3. #63
    MySQL Error
    Oct 2004
    what is "run the radio command"
    looking at your log, its all correct
    your "wasradio" didnt change, so it still set to xm..
    like i said before, RR source handling isnt so good
    what is ur radio? hd radio? turn on hddebug=true
    without that log useless...
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  4. #64
    MySQL Error
    Oct 2004
    as for sat and ter lables, who knows...
    i just added them in with all the rest, if the rest update, these should too
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  5. #65
    Woodbridge, VA
    Blog Entries
    32
    mitch
    i ran the RR command "RADIO" which turns on the radio and goes to radio_player.skin. If wasradio didnt change then why did xm turn off and radio become tunable (cant neccessary hear it because of lack of line-in... but usually if radios not working at all frequency wont tune to stations)? And i do have HDDebug=true in rr.ini. Least i believe so.. i'll double check maybe it got erased somehow
  6. #66
    MySQL Error
    Oct 2004
    i didnt see any hd radio debug stuff... maybe i missed it
    i look, yes sorry there is SOME..
    sorry no need to look...
    when u went into radio...
    7/3/2008 8:06:47 AM: XM---> XMInActive: XMON=False
    7/3/2008 8:06:47 AM: XM---> oXM_XMEventRadioReady:
    7/3/2008 8:06:47 AM: XM---> XMPoweredON: XMON=False,XMTuneTo=0
    the XM just came alive
    but i NEVER SEE ANYTHING from HD from this point on
    the log is HD FREE from your resume at 8:06:44
    NO log entries for the HD Radio powing on...
    7/3/2008 8:06:44 AM: HD---> HDRadioPowerOn:
    7/3/2008 8:06:44 AM: HD---> HDRadioPowerOn: frmCOM.oHD.Open
    thats why it failed
    it tried to open the port, and couldnt
    and this
    7/3/2008 7:59:43 AM: ResumeFromHibernate: Start tuners... Sirius, XM, & HD
    7/3/2008 7:59:43 AM: XM---> XMLoadIn: xmcache.ini, XMLastChannel=140
    7/3/2008 7:59:43 AM: XM---> XMLoadIn: End Sub
    7/3/2008 7:59:43 AM: XM---> XMPowerON: .Open
    7/3/2008 7:59:43 AM: HD---> HDRadioPowerOn:
    7/3/2008 7:59:43 AM: HD---> HDRadioPowerOn: frmCOM.oHD.Open
    7/3/2008 7:59:43 AM: CheckResume: ResumeMusic=2 WasRadio=2
    7/3/2008 7:59:43 AM: XM---> XMActive:
    7/3/2008 7:59:43 AM: XM---> XMActive: PORT not OPEN, waiting...
    7/3/2008 7:59:43 AM: XM---> XMActive: XMON=True, XMTuneTo=140
    7/3/2008 7:59:43 AM: XM---> Radio not found
    7/3/2008 7:59:43 AM: HD---> oHD_HDRadioEventSysPortOpened: .PowerOn
    7/3/2008 7:59:43 AM: XM---> oXM_XMEventPortOpened: .PowerOn
    7/3/2008 7:59:45 AM: HD---> oHD_HDRadioEventHWPoweredOn
    7/3/2008 7:59:45 AM: XM---> oXM_XMEventRadioReady:
    you are still having some hardware issues...
    this is wierd
    then it got the port open...
    and why do i see double log entryies in UR log...
    are u still band-aiding anything? if so remove it
    at
    7/3/2008 7:59:39 AM: ResumeFromHibernate:
    then
    7/3/2008 7:59:40 AM: ResumeFromHibernate:
    why is resumefrom hibernation called many many times on ur system!
    is windows sending you resume messages??!?!?!?
    ResumeCheck
    make sure its 0
    ResumeCheck=0
    there is only two places one canget to "resumefromhibernate"
    one some some "ResumeCheck"?? and the other a OS windows message...
    and why the f is 7/3/2008 8:06:44 AM: ResumeFromHibernate:
    event here, ur not hibernating!!!
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  7. #67
    Maximum Bitrate fixerofallthing's Avatar
    May 2005
    Lawrenceville GA
    I just wanted to drop in again and say GREAT JOB!! Everything is working great with no delays and all functions working perfectly. Thanks for all the hard work mitchjs.
    The Car 2005 Scion xB
    The Truck 2004 GMC Canyon
  8. #68
    MySQL Error
    Oct 2004
    thanks, what radio systems you got? Xm, Sirius, HD Radio....
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  9. #69
    Variable Bitrate PontiacGA's Avatar
    Mar 2006
    Pennsylvania
    Wow! Much improved! Thanks again.
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
  10. #70
    May 2005
    Lawrenceville GA
    XM and HD
  1. RR 09-30-2007 ... HD Radio & some more..
    By guino in forum Road Runner
    Last Post: 10-20-2007, 10:01 PM
  2. XM issues with RR
    By dseoane in forum Road Runner
    Last Post: 08-10-2007, 06:10 AM
  3. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
