ok, next and prev, is now all completly rewritten
they now move through the ACTIVE list
which created another issue, favs are out of sort, i fixed that too
will post later... got 2 people testing...
mitch
mitch
-Thanks
Mitch
www.rush2112.net
Sun, Come shine my way
Wind, Carry me home
The piece of me that died
Will return To live again
Still having random XM/HDRadio issues. When I left work yesterday (4:45 pm), I was having problems with Radio & XM, and you can see that I was clicking around trying to get something to respond. I rebooted (5:07 pm) and the first thing I tried was radio… it worked, so I listened to that for a while, then changed to XM… it worked, so I listened to that until I got home. This morning, (5:53 am) , XM wasn’t working, neither was radio. That’s when I copied the log to my thumb drive. I think radio resumed once I changed the station…. All this is from memory, so I may have forgotten a detail or two (sucks getting old!)
MSI K9N6GM
1 gig RAM
8" Lilliput
Onstar GPS mod
XM
Visteon HDZ300
Barnyard are you using the latest version? I had a similar prob. until I installed the latest version AND run the run me first thingy. So far I am happy with the latest version.
what is the latest version anyway...
ill refresh now
see 1st post!
mitch
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
barnyard, i looked at your log, you are having HW issues
i quick guess, is HD Radio is wired WRONG...
it is OFF before your PC is in hibernation!! where is that RED wire connected to?
looked ok on 7/2-7/6, but 7/7-7/8 no
i am seeing incomplete prepareforhibernations
look at this nightmare
7/7/2008 5:31:01 PM: PrepareForHibernate: (Start)
never fully finished... and the next morning
7/8/2008 5:53:54 AM: SDK command: REQUEST;MotionLock;RRSCREEN||REQUEST;MotionLock;GP SSPD
7/8/2008 5:53:55 AM: SDK command: REQUEST;MotionLock;RRSCREEN||REQUEST;MotionLock;GP SSPD
7/8/2008 5:53:56 AM: HD---> oHD_HDRadioEventCommError: Error= Queue timed out, NO response from tuner on last command: A4 04 01 01 01 00 AB
7/8/2008 5:53:56 AM: ResumeFromHibernate:
so prepare never completed...
ON TIME
look when it did
7/8/2008 5:53:57 AM: PrepareForHibernate: End Sub
so its really simple why you're having problems!
you are not completing PrepareForHibernate, before the pc switches OFF
1st guess would be, a power problem on HD Radio, and maybe XM Radio
tell me about the power connections!
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
Mitch, both XM & HDRadio are connected to a molex. Both red & yellow wires on HD are terminated to the yellow (12V) on the molex. What else would cause it to not complete?
Thanks!
Mitch, I just tried the 7-8 version, and it hangs at 'starting serial devices...' I went to an older RR version, and it works fine. Any ideas?
both red and yellow on HD, on 12v on molex, molex meaning Hard Drive Connector?
and XM is powered same way... which xm interface?
did u run, the MJSG-RR-RunMe1st.cmd in the main, directory?
i dont remember if i made any changes... to com objects, best run that 1st
but a log would help...
nothing there should hang it
mitch
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
also, start a new log, delete debug.txt before u run RR
mitch
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
