HELL YES, works great!
Even fixed my compass indicator!
You da man!
******* UPDATED 7/18/2008 ********
+ fixed Signal Strength on resume
NEW XMComm.dll you must register new dll
7/11/08 / 7/15/08
+ removed messagebox alert on xm issues, added more xm debugging log
+ has support for MJSG UAS
+ completly rewritten, next/prev channel for XM
+ will use FAVs correctly
+ added safety check on FAV list entry
+ added safety check for invalid FAVs
here is the public release... a couple of things must be noted.
THANKS TO: Dave323Ci, for all the testing!
the RR source code is based from 11/2/2007, since thats the NEWEST i could find
Do not use fadevolume, set it to fadeinvolume=false, unless you are using the winamp line in plug in for ALL sources. Complicated to explain why, but it needs a complete concept rewrite.
XM Radio was completely rewritten.
- XM Channels arnt cached, they load on each run. it might be cached in future, but for now no. its a quick load, and happens in background.
- favorite lists,load in too..
HD Radio improved.
switching between HD/XM/Mp3 should be instant.
RR will also resumemusic to HD/XM/Sirius/MP3 when RR loads, based on last used source (resumemusic=2)
HD Radio and XM Radio is "always" on, also power for these devices must be done correctly. each radio MUST be on when the PC is on. that simple. for example on HD radio, there is a Yellow and Red power wire. the YELLOW is constant 12volts, the RED needs to be on when PC is on, therefore best connection would be Hard Drive +12volts. XM Radio, depending on your set up, has a 12Volt power connection, this needs to be on when pc is on, so again Hard Drive +12volts. A good solution is a PC power controlled relay.
I havent touched Sirius(yet), infact i havent tested it at all... hopefully it still works...
some new RR.ini commands
XMDebug= (true/false)
HDDebug= (true/false)
debugmode=true, must be set to use the above
also... there is a new LPT amp control built in, but more on that later
Backup:
roadrunner.exe
xmcache.ini
unzip MJS-RoadRunner.zip to your RoadRunner directory, overwriting ALL files
there is a new hdcomm.dll and xmcomm.dll
then run in the RoadRunner directory: "MJSG-RR-RunMe1st.cmd" this will register the control classes
with your system
set all you settings in RR.ini
xmtype is no longer needed
xmport=x, where x is the comport that xm is connected to
prob so much more info i need to get accross ... but enough for now
*** UPDATED ****
-Thanks
Mitch
www.rush2112.net
Sun, Come shine my way
Wind, Carry me home
The piece of me that died
Will return To live again
You da man!
2011 Nissan Frontier SL
AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
this new version works for me as well in my limited testing.. the audio resumes as it should and everything.. thank you VERY much for this mitch. Lets make sure to get this into the next official release .. whenever that may come!
Live mp3Car Facebook Chat
Or the next official beta
TruckPC - gutted, being used for test setup
BoatPC - off season - Inelmac screen needs serviced again!
BlazerPC - last vehicle PC I'll build
Just quickly tested and works great! I love the continuous updates for the hd radio. Keeps getting better and better.
Thanks agian mitch!!..
Some notes after a couple days worth of testing/using...
-this morning upon turning on my car rr resumed xm as it should have, but there was NO audio, the playlists were updating as they should but no sound was coming from the xm unit, audio player had sound, other sources plugged to line-in had sound. but xm didnt. i had to turn my car off power down the xm device and restart for it to come back
-resuming with xm makes it so that the audio player ignores resume.ini. This means xm resumes, but once u switch from xm to audio audio player is stopped and does not resume where it was last playing.. not a real big deal just something i noticed
-ONSONGSTART is not working still.. thats pretty important
-Sometimes upon resume from hibernation with XM as last played source the playlist contains duplicate entries. Seems this could be solved by clearing the list at hibernation
now questions..
-What is the name of the variable that states which source is playing?
- I requested this in the beta thread but it doesnt seem to work... is it possible to get the signal strength sliders as a label/variable. Us guys using flash cannot use the existing signal strength slider.
sonic,
it sounds like ur not using the latest version, seeing duped entries...
i have not idea what "ONSONGSTART" is....
hmm... variable that stats which is playing... i dont think there is one
signal strenght as vars, maybe... i dont know how
mitch
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
the duped entries may have something to do with the fact that i'm using a flash skin and i'm poling the playlist from the CUSTOMPL label. it just seems that the xm device is sending data to the CUSTOMPL label without clearing it first. If i switch a to a different favorites list then back to the resume list the problem corrects itself. I'm using the version posted in this thread
ONSONGSTART is an rr event which performs a user-defined command everytime a new song starts in winamp. With your version of RR the user-defined command doesnt run when a new song starts in winamp. You can find how it works in the TimerUpdate_Timer sub in frmSkin
creating a variable for hte playing source should be easy. I mean the variable could be named $PLAYEDSOURCE$ and would be set anytime a new playing source is started, options would be AUDIO,XM,SIRIUS,RADIO, or VIDEO. Doing this would allow users to have buttons run different commands based on the played source. Get it?
as for the signal strength requests, it should be pretty simple as well. Right now RR stores the satellite signal in "XMSAT" and terrestrial signal in "XMTER". This two elements can currently only be accessed in a slider. I'd like it so that the stats could be displayed in a simple percentage, or hell even 0-10 would do
all this stuff i can do later so dont stress too much about it.. i just feel there could be further improvement along those lines
as for flash skin, i have NO idea, i have no idea what "CUSTOMPL" is, the PL is cleared on the start OF XM, thats a fact.
the XM signal data is basic 0-3
the var for playing is out of the scope of what i want to do... you will have to add
REMEMBER i dont use RR!! no car pc for me![]()
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
OK i found the ONSONGSTART
I can fix it, just bad use of variable naming
"If Car2PCTI <> LabelInfo("TRACKNAME") Then"
as for your CUSTOMPL, maybe ur getting PL before the XMLOAD even happens... but that would be ok, unless the forms.showpl is false on falsh skins... cause is soon as xm play list should be shown, the 1st thing i do is...
If .ShowPL Then
.PL.Clear
send me ur skin
mitch
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
