try the
/DISCARDABLE
before the buttons.
Any idea what would cause this?
This skin is called from a button with this code:
"LOAD;EXIT_GPS.skin"
EXIT_GPS.skin
When the skin is called, road runner just minimizes, and will not do anything unless restartedCode:RoadRunner Skin RRScreen "EXIT_GPS" Skin EXIT_GPS_OFF.jpg,EXIT_GPS_OFF.jpg,EXIT_GPS_ON.jpg,EXIT_GPS_DOWN.jpg [Yes/No/Setup Button] B01,176,357,105,86,"CLOSEWINDOW;$gpsname$||MAIN","CLOSE GPS" B02,335,353,140,90,"LOAD;GPS_SELECTOR.skin","" B02,529,356,105,86,"GPS","ABORT" I,194,84,124,133, /DISCARDABLE END
All jpegs are there (at same 800x600 resolution), all matching the names in the skin file, all seems ok when using the skin editor (on/off/down works ok)
Any ideas?![]()
CarPuter Progress:
Planning:-----> [||||||||||] 100%
Hardware Buying:-> [||||||||||] 100%
Software:-----> [||||||||||] 100%
Installing:-----> [||||||||||] 100%
Current Project= Making skins in photoshop...
try the
/DISCARDABLE
before the buttons.
E,
Hmmm starting to think it may be my config, does the same on VirtualPC and my desktop PC.
The commands all seem to work when using the skin tester (JohnWPB) and load OK
Can you take a look at the attachment?
The idea is you click the power button (On External GPS skin), it displays a confirmation skin (EXIT_GPS.skin)
Yes= Close GPS
No= Return to GPS screen
Setup= Calls "GPS_SELECTOR.skin" which will adjust the RR.ini setting
This is the aftermath of the project you helped with, which was also bugger to code![]()
CarPuter Progress:
Just gave it a quick go.
The GPS_EXIT skin worked fine.
However selecting GPS Selector caused RR to disappear totally and I can't get back by using ESC and have to CTRL-ALT-DEL.
Will have a further play after I have fed family etc. . .
Cheers E
Tried it in my car this time, and its the same for me as well.
Must be something in my skin files thats causing it!
Also using the restart button on GPS_SELECTOR skin also causes RR to restart OK, but the screen reloads out of alignment, and buttons are off the screen!
CarPuter Progress:
Well I have solved the issue I was having by, changing the 2nd button in the exit screen to:
B02,335,353,140,90,"exit||LOAD;capture.skin",""
What does this change? did you rename any of the skins?
Either that or you were being sarcy!![]()
CarPuter Progress:
Like I said initially, The GPS_EXIT skin worked fine, it was only when I clicked on the GPS selector button in the exit skin that I got an issue.
I'm wondering if it is anything to do with loading another skin from a skin that was called from a discardable one.
I will experiment a bit more later today.
Good point, as always thanks for the help.
I always use that for non essential skins, so it doesnt keep hogging the ram
CarPuter Progress:
