Results 1 to 6 of 6
Thread: Weather based on GPS position
    Jan 2006
    Michigan
    I just installed the weather version and got it to work. Its a nice option, but was wondering if it were possible for RR to use GPS coordinates to show local weather? I know the location is encoded in the cfg file, but is there a way around this?
    Thanks,
    DNR
    SD beats everything. So there. danielkh's Avatar
    Sep 2007
    Beaverton, Oregon, United States
    Are you talking about the live screen only? The weather and forecast page does use GPS coordinates to give local weather. As for the live page, I just center it on my home and set zoom level to cover most places I drive.
    If you can't get the local weather on the opening page, check this in the rr.ini file (someone correct me if I am wrong)...
    [Weather]
    cityweather=Austin, Tx
    weatherunits=USA
    weatherdegress=
    localdatacaptureinterval=1
    My opinion is my own.
    Jan 2006
    Michigan
    Weather based on GPS Location
    Thanks. I found the thread with all of the details.
    DNR
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    localdatacaptureinterval is the interval in which RR reads your gps coordinates into zips.dat to determine your current location. The options are 1,2,5,10,15,30 and correspond to minutes. If you have this option enabled in RR.ini the weather will always be based on your current location unless you run the HOMEWEATHER command which takes the weather from your rr.ini declared location
    Live mp3Car Facebook Chat
    Nov 2007
    Quote Originally Posted by dnr250 View Post
    DNR
    Which thread is that?
    [98%]
    Jan 2006
    Michigan
    Where is the thread?
    Here it is:
    http://www.mp3car.com/vbulletin/rr-f...m-solving.html
    I had to search for it and found it by mistake.
    DNR
  1. Local weather map using GPS data or Zipcode
    By obrienj in forum Road Runner
    Last Post: 09-30-2007, 07:41 PM
  2. Replies: 5
    Last Post: 05-17-2006, 10:23 AM
  3. FS: USB GPS Mouse
    By nappyjim in forum Classified Archive
    Last Post: 02-21-2005, 10:48 PM
  4. Live weather linked to GPS ???
    By dumpper in forum GPS
    Last Post: 09-22-2004, 01:39 AM
