Results 1 to 9 of 9
Thread: volume level on resume from hibernate
    sometimes when I resume from hibernate the volume level in the mixer for whatever I'm using i.e. digital in for Sirius, or winamp for music is all the way down. What would lower the volume on these things when I resume from hibernate? I tried "roadrunner is aware of hibernate etc etc" in the config tool and it really doesn't seem to affect anything.
    thanks
    Maximum Bitrate fixerofallthing's Avatar
    May 2005
    Lawrenceville GA
    Quote Originally Posted by turbochris View Post
    thanks
    try turning off the fade in volume on resume setting in RRConfig. It fixed it for me.
    The Car 2005 Scion xB
    The Truck 2004 GMC Canyon
    FLAC Griff1's Avatar
    Nov 2005
    Midlands
    Yeah i had the same thing.
    P4 2.8 HT, 512Mb Ram, 60Gb 2.5 HD, M4-ATX, SB Audigy2, BU353, Lilliput TS,Soundgraph Imon VFD,SONY Optiarc dvd Burner,RideRunner, iGo8, Custom Freedom 2.1
    Nov 2005
    RR raises the volume of winamp from 0 up to where it was previously. you can actually watch winamps vol slider go up (if the winamp window is visible). you may also try disabling volume control (Preferences>output plugins>Directsound>configure>Other>Volume Control) on the winamp side of things, and it might make winamp locked into full (100%) volume at all times.
    MySQL Error
    Oct 2004
    DONT USE VOLUME FADE!!!! its conceptually bugged... would need a complete rewrite of audio management in RR
    fadeinvolume=false
    UNLESS!
    you are using winamp FOR ALL AUDIO MANAGEMENT
    ie. all sources use winamp, like XM, Sirius, HD and etc. must use the WINAMP LINE IN PLUGIN
    and NOT the Windows mixer
    THEN fade would be OK
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Feb 2007
    Quote Originally Posted by mitchjs View Post
    fadeinvolume=false
    UNLESS!
    Mitch,
    Do you know why it works sometimes but not others? I don't mind turning it off, but I do enjoy the effect. Thanks!
    Nov 2005
    I think it has something to do with not getting focus on the winamp window for long enough to issue the fade=in command. It switches back to RR focus to early, in some cases. But thats only a guess based on what I have observed.
    MySQL Error
    Oct 2004
    yes... i know exactly why it doesnt work...
    hard to explain... i would rewrite it if it was easy...
    its because how audio is managed in RR all together
    some audio is MIXER managed, and MP3s are WINAMP managed
    prob should all be dumped, for say a single audio system, like BASS Audio Library
    but if u use winamp for EVERYTHING (XM, HD, Sirius) and RR not touching the mixer for volume... it might work... its also tied to the fact that RR resumes last source as MP3 (now thats fixed in my version)
    also the volume isnt tracked by RR, it assumed to be in winamp... and winamp volume 0-255 has NOTHING to do win MIXER VOLUMES 0 -65535, so i see the mixer volumes get so messed up
    just dont use it
    audio VOLUME should be managed at 1 point!! which its not
    prob could do a work around fix, the keep RR from touching the LINE IN VOLUMES
    but then they wouldnt fade up, just like i dont think it should be touching WINAMP volume, volume should be controled at the OUTPUT side, not on a SOURCE
    source meaning mixer input, winamp
    not to mention VISTA audio management, which is ACTUALLY AWESOME!
    maybe a rewrite to RR to fade volume with MASTER, it might work
    i know, i dont know enough about RR, i dont use RR (im not carpc nut, hehe), but i have been deep in RR code alot lately
    mitch
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Feb 2007
    Yeah, I think taking the Hardware Abstraction Layer away in Vista was a good move, even if a lot of manufacturer's hated it. Simpler for applications. Thanks for the information.
  1. Hibernate and Vis and Resume
    By RichP714 in forum RR Bug Tracker
    Last Post: 09-22-2007, 03:43 AM
  2. Set Volume at Start and Resume from Hibernate
    By efficinet in forum Software & Software Development
    Last Post: 02-01-2007, 10:33 AM
  3. Resume after hibernate scrutinized
    By ldave in forum PowerVoice
    Last Post: 02-10-2006, 12:04 AM
  4. Resume from hibernation, Volume level at 0
    By blackflux in forum General Hardware Discussion
    Last Post: 04-08-2005, 03:19 PM
  5. Audigy 2 NX full volume after resume
    By STI_FFY in forum Car Audio
    Last Post: 11-22-2004, 10:38 AM
