Page 4 of 7 FirstFirst 1234567 LastLast
Results 31 to 40 of 69
Thread: Road Runner locks on resume from hibernate until menu click
  1. #31
    Sep 2008
    2 mitchjs:
    I use my own logging program. You may use SPY++, it can log and filter any windows messages of any window.
    Note: mswindows sends WM_PowerBroadcast message only to top level windows.
  2. #32
    Aug 2004
    Germany
    Touchscreen: SP7
    Board: Intel D201GLY
    OS: Windows XP Pro SP2
    RAM: 1024MB
    Screen stays black until I touch the screen. I'm almost sure that the Intel board is the culprit, because I didn't have this problem with the board I used before (identical installation except other drivers for the board).
  3. #33
    MySQL Error
    Oct 2004
    Sborovkov, log a session of a resume...
    id like to see all messages to RR once we come out of sleep
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  4. #34
    MySQL Error
    Oct 2004
    wywywy... ITS NOT A HARDWARE PROBLEM!
    this is done on purpose, just doesnt help carpcs
    which offically i dont think there really is a class of PCs
    at least from Intels point of view
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  5. #35
    Sep 2008
    2 mitchjs:
    two logs are in attached file. carmess.log is created on CarPC based on intel GLY motherboard. UsualPC_Messages.log is created on my notebook. There are some my comments in log files.
    carmess.log has many mouse events. I think it is because of touch screen drivers.
    You'll see strange messages (wm_user+10) on the log such as:
    "message:0x040A [User-defined:WM_USER+10] wParam:00000011 lParam:00000006"
    These messages i sent to RR to define time of the incoming messages. wParam is system minutes and lParam is system seconds.
    Windows on intel GLY motherboard sends WM_POWERBROADCAST only after user moved mouse, pressed any key, or did any other user event.
    Other PCs sends WM_POWERBROADCAST immediatelly after PC was ready to work.
    This is not i bug of RR. I think, it is because of bad (via?) drivers...
    My CarPC hybernates itself as Stealth915's one.
    I did a quick test today and can confirm that the computer hibernates by itself after about 5 minutes if I don't touch the screen while it is hanging
    It occurs regardless of RR presence in memory. More precisely, PC is not hangs. It doesn't sleep, but it doesn't wake up fully. Winamp can play music on my PC on such conditions. As i understend, RR waits for WM_POWERBROADCAST so it doesn't repaint itself.
    Two month ago i wrote a small program. It had to mute sound before hybernate and unmute it after waking up (i wanted to remove loud BUH from speakers). Program worked normally on home PC, but didn't work on CarPC. I added messages logging and did recognize strange behaviour of windows.
    ps. sorry for my bad english.
    Attached Files Attached Files
  6. #36
    Feb 2007
    netherlands
    i had it that after hybernate there was no sound, i had to restart RR.
    But it turned out to be winamp. It lost my usbcard. There is a resum plugin at the winamp site and and after installing that, no more problems on hibernate.
  7. #37
    MySQL Error
    Oct 2004
    sborovkov, can you join me on msn messenger
    i want to build a special rr build
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  8. #38
    Sep 2008
    Hi Guys,
    I have just come across the discussion below which may be of some help.
    http://forums.fluxmedia.net/general-...ch-screen.html
    Cheers,
    Scaven
  9. #39
    Sep 2008
    Quote Originally Posted by mitchjs View Post
    what is msn messenger? I used spy++ to log messages for attaching. You can get it here.
    Run it, press ctrl-f, then drag "finder tool" to RR (or any other) window. select "messages" combobox, then "OK". You'll see messages of window.
  10. #40
    Feb 2006
    So, if we write a small program that sends out the required WM, and run it with Hibernation Trigger, it should be ok?
  1. Road Runner Installation Program
    By bry21317 in forum Road Runner
    Last Post: 01-29-2008, 10:22 PM
  2. Road runner Ideas (BIG LIST)
    By sephiroth7 in forum Road Runner
    Last Post: 04-01-2007, 10:50 AM
  3. Replies: 4
    Last Post: 12-27-2006, 04:22 PM
  4. Cingular PDANet via bluetooth
    By DarquePervert in forum Wireless Communications
    Last Post: 06-23-2006, 05:22 PM
  5. Road Runner Facts...
    By guino in forum Road Runner
    Last Post: 02-21-2005, 12:16 PM
