Results 1 to 8 of 8
Thread: rr help needed
    Maximum Bitrate albysure's Avatar
    Dec 2000
    pittsfield, ma.
    rr help needed
    i switched over to rr and gave it a trial run on my home pc over the winter. today i went to the car pc and put all the files on it. i just get the "send" "don't send" microsoft error box on both rr and rr config. please help. what am i missing?
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Probably need to give more info on the error.
    Tidder
    Try RevFE
    Jan 2007
    East Central FLA
    A guess would be that you just copied files over and did not do a RR install on the car PC - in which case several of the dll files need to get registered with windows.
    Dec 2000
    pittsfield, ma.
    i put all the files on a flash drive and copied them to my cap hd. this didn't work. so i just downloaded the files onto my car hd from here. still nothing. when i try to open rr config i get that box to send or don't send to ms. also there is another box from rr that says there is not the right skin loaded.
    Dec 2000
    pittsfield, ma.
    across the top it says
    "autolt v3 compiled script has encountered a problem...
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Firts off, download the latest RRConfig.exe from Blue and run it.
    Under Skins, select the path to your skin folder and go from there.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Sounds like you are running a lite'd version of windows and it doesn't have some of the support files required to run VB or Autoit programs.
    Dec 2000
    pittsfield, ma.
    well i downloaded another version of the installer and it works fine. thanks
  1. RR Newb... need help/suggestions.
    By Nola111 in forum Road Runner
    Last Post: 03-12-2007, 08:10 PM
  2. RR Embedded IGuidance causes RR to lose focus
    By durwood in forum Road Runner
    Last Post: 11-10-2006, 10:31 AM
  3. Permission needed for RR skin release
    By CdRsKuLL in forum CF Skins
    Last Post: 07-31-2006, 07:27 PM
  4. Dialup in RR without Phoco?
    By kbreeden in forum Road Runner
    Last Post: 12-12-2005, 09:04 PM
  5. IE in RR bug
    By accentsound in forum RR Bug Tracker
    Last Post: 07-10-2005, 02:21 PM
