Results 1 to 10 of 14
Thread: Ok. dual screens 1 controls the other w/ multiple instances.
    Jun 2003
    Memphis - TN
    Here's what Im wanting to do, any help would be appreciated.
    Dual screens...
    One up front that is a touchscreen, one in the back thats just a display.
    I have 2 soundcards one to the cars speakers, the other to a set of speakers by the rear display.
    I know I can run 2 instances of roadrunner, and I can set up Mediaplayer Classic to use the second soundcard while winamp is playing on the 1st, tested and works.
    I know I should be able to have two instances of MPC as long as they are running in different directories, so I can play videos up front, on one soundcard, and another on the back screen using a different sound card ( I need to test that)
    But.. how do I control the second instance of roadrunner, on the second screen from the other instance? Basically I want to be able to open the videos up front, have them playing on the back, but still be able to open and watch a different on the front one.
    Also, any way to have a skin, on a second instance, be just a video player (to reduce memory footprint)?
    Any help would be appreciated.
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
    Jun 2003
    Memphis - TN
    Update, if MPC is running in a different directory, I can run 2 instances. You just have to rename MPC.ini to mplayerc.ini, in the settings set the output to the other soundcard, close, then rename to mpc.ini again.
    In RRconfig I set the start command to VIDEO, and on the second instance, it went immediatley to the video screen. I can just delete all the other parts of the skin I dont need.
    Now I just need to find out how to control the second instance of RR's MPC from the 1st instance/screen.
    Jun 2003
    Memphis - TN
    Its there not anyway to send commands from one instance to another?
    Apr 2006
    Clearwater, Fl
    Quote Originally Posted by Custommx3 View Post
    I'd like to know this too...
    Maximum Bitrate tundra2000's Avatar
    Mar 2006
    Houston, TX
    all i can suggest is some more searching, a reading of skin commands.txt, and possible messing around with EXEC.exe. you can send commands to EXEC.exe and RR will execute them. now which one will be controlled, or if different 'EXEC.exe' 's control different RR's, i do not know.... i looked into somethin like this before too
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Does not the second roadrunner have a different window title, if so try sendmessage to the window title.
    Jun 2003
    Memphis - TN
    Well, seems I cant get it to do what I need to do...
    so I will ask this. When your playing a video... and you press BACK or MENU to get to the main menu, it stops the video. Can this be disabled? That way I can just have the video overlay set to the external monitor, turn it on, and then go back and its still playing on the second monitor.
    lambosprit's Avatar
    Sep 2006
    UK
    Not sure if this is what your after but its exactly why I created my rrvlc plugin.
    I have freedom ultimate running in the front with my rrvlc running on the back two monitors. I have made a version of ultimate that allows me to control the video and its playlist from the front without stopping the music in the front. If you want help with using it in any specific skin I can help there.
    Jun 2003
    Memphis - TN
    can RRVLC have sound output to a different soundcard? I know with MPC, you can, its ini file, specify a particular soundcard.
    Basically, Im putting a headrest monitor in my backseat for my child. I'll use a sepaprate soundcard for its audio, to speakers mounted on his carseat. The rest of the audio will go through the second soundcard.
  1. Duel screens - One for controls and the other for video/vis?
    By mikerosoftx in forum Software & Software Development
    Last Post: 03-31-2005, 09:15 PM
  2. Dual Screens - 1 for Display 1 for Controls
    Last Post: 03-27-2005, 02:48 PM
  3. multiple screens
    By yonu in forum Software & Software Development
    Last Post: 03-01-2005, 06:01 PM
  4. Multiple Instances of FrodoPlayer
    By antimatter in forum FrodoPlayer
    Last Post: 08-19-2004, 11:45 PM
  5. Two screens with separate controls?
    By bugsoup in forum LCD/Display
    Last Post: 04-25-2002, 02:53 PM
