with my version, they should populate within 30 sec
sounds like you got NO SIGNAL (or really weak), did u do what i said, forget RR.../
use SID (my sirius demo program)
mitch
with my RR, its impossible to have out of order channels
and what is this log, not from MY VERSION OF RR
there is no 8/5
also, is not having audio ur issue?
u need to tell me about how ur managing audio
prob has NOTHING to do with my RR or Sirius
ok, im heading out for night 1 of fireworks
mitch
-Thanks
Mitch
www.rush2112.net
Sun, Come shine my way
Wind, Carry me home
The piece of me that died
Will return To live again
mitch
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
I'm just trying to figure out what is going on. I didn't have these issues until I became a tester for the your version. I want to make it clear that I am not blaming your code, because as far as I know, it has worked for others. Like I said, I am just trying to find out what went wrong, as the problems started when I made the switch.
I just tried the Sirius Recorder, and no audio. The channels loaded, but no sound. It may be due to the fact that I can't do digital in, at the same time as analog out on my card. This is why I use the Winamp Line-In plug in with RoadRunner. I am unable to figure out what has changed, besides loading the new RR from Mitch. The After that, Sirius didn't work anymore, even though it was working right before I put in the new RR from Mitch. The battery slider ( In Road Runner and the Sirius Recorder) shows both strong Satalite, and Terrestrial Signal.
Another weird thing is that my Sirius channels still show out of order. I even reloaded the Digital FX 3.0 skin, and the channels were still out of order! I am at a loss as to what could be wrong now.
duh, try analog audio
and USE SID
not sxrecorder, not anything else..
get it all working with SID (Sirius Interface demo...aka my sirius demo app)
mitch
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
I can try that, but I would have to rewire, and change my audio settings in windows... If I'm not mistaken, I think that I may still have the old wire ran, I just have to verify.
Any chance in the future that you may make something that would utilize the Winamp Line-In plugin for those who have soundcards that can't do both Digital In and Analog out at the same time?
did i not say forget rr, get your sirius working 1st
i dint change anything in rr, the winamp line in plug in still works
(or it should, if it worked before)
im telling you, that right now, maybe ur sirius is bad... cause you keep saying i get no audio
mitch
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
in sxrecorder, use the audio monitor too... that allows u to listen to and "PIN" on a mixer live
mitch
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
I still need a SIRIUS TESTER
mitch
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
