im at 8/7/008
rr doesnt look for install file, its because u set up rr with that MSI installer version, MSI installer sees that "roadrunner.exe" has changed, and wants to repair it
best bet, is cancel, then use the MSI Clean up tool
http://support.microsoft.com/kb/290301
LinkBack URL
About LinkBacks
I noticed that my CPU stayed right around 100% utilization, and my channels changed slower. The icons didn't change in some cases either. I switched back to the 5/27/08 version of RR, and the CPU utilization went back down. My list issue also remains fixed. That was probably a function of the skin. If you look at my specs, you will see that my system is not a high performer.
