Results 1 to 3 of 3
Thread: embeding mappoint
    Mar 2008
    embeding mappoint
    ok I am having a problem and if anybody can help me out I have the latest rr and mappoint 2006. In the rr config I have pointed the gps to mappoint.exe and put Mappoint in the window name box and put the port number of my gps in the port box and also marked for mappoint on the radio buttons but on the default skin if i push gps nothing will happen at all and when I use digital fx skin the latest 4.0 one and change the button to be the mappoint button when i push it it will open as a window on top of rr so if I push and button on rr then it goes behind rr and it will not show where i am till I push track gps on mappoint what have I done wrong if someone could let me know or point me to a post that would help because I did a search several different ways and could not find anything about this problem
    Maximum Bitrate v8 scimitar's Avatar
    Jan 2005
    Things might have changed (I use an old version of rr) but all you had to do was set mappoint in RR config and it worked. Its the built in solution for RR so no mapping exe's or anything like that. Just set the radio button in config and put the port the reciever is on in and your done.
    Appologies if this has changed.
    Visit my site V8 Scimitar
    SP13000, 300GB SATA HD, 1GB DDR. Opus 150, K301 screen, Cisco WIFI, AQmax GPS, RoadRunner and FreeDrive, Sony MEX-R5 head unit. 4 years installed and it just keeps running!
    Mar 2008
    ok you were right on just selecting the mapoint and not inputting it to point to mappoint but I am still having the problem that the default skin does nothing when you click gps and then in digital fx skin it still opens it as a window and none of the buttons on the skin do anything at all to mappoint
  1. Replies: 33
    Last Post: 05-30-2007, 09:54 PM
  2. mappoint wont install on network
    By chewEboy in forum GPS
    Last Post: 01-24-2006, 05:39 PM
  3. BMv2 Mappoint 800 * 480 .Skin Files
    By IntellaWorks in forum RR Skins
    Last Post: 11-14-2005, 03:03 PM
  4. RR 3-30-05 ... Mappoint ...
    By guino in forum Road Runner
    Last Post: 04-06-2005, 12:47 AM
  5. Replies: 13
    Last Post: 07-15-2004, 12:07 AM
