Results 1 to 10 of 10
Thread: how can i embed any program into a generic skin file?
    Dec 2007
    I know how to embed a program into rr, but you need a skin file for each program. That's not my solution.. here's my situation.. i wanna able to run any executable(short cuts) from the list and load that into one generic skin and run.. I am in the middle of creating game.skin... game list may contain, mame, pc games.. etc... clicking any one of them should fire a specific game.. Is this doable?
    Thanks as always..
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    very possible, just use a variable to set path, window name,
    i.e.
    Code:
    "LOAD;generic_app.skin;$TTS$;$APPPATH$;$APPNAME$"
    where:
    TTS holds what RR will say when loading the screen..
    APPPATH holds the path for the selected application..
    APPNAME holds the applications window name..
    of course you need to set the variables value first. depending in how you will select your applications you will set the values, maybe from a custom list?.
    using a custom list:
    Code:
    "CLADD;path1;windowname1"
    you must repeat this step for each application.
    and the button code for run the selected application would be like this.
    Code:
    "SETVARBYCODE;CLTEXT;APPPATH||SETVARBYCODE;CLDESC;APPNAME||LOAD;generic_app.skin;GAMES;$APPPATH$;$APPNAME$"
    try it, i think it will work.
    Dec 2007
    Thanks El Camino.. Could you be little more specific? which code goes where?
    this is the flow i have in mind.. i click game from menu screen which will load the game list screen... I assume this is where SC needs to be defined... when an item from the list is selected, I press play button which will will load a game in a generic skin...
    Given that, I am not sure how to assoicate or figure out ur code with approprite screen and control... And what's CLADD?
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    See Skin Commands.txt for CLADD.
    EC pretty gave you most of the code you need to do what you're trying to do.
    CLADD will be used after you load your game_menu.skin and that command will populate your SC list.
    game.skin >> button to load menu >> game_menu.skin >> CLADD or CLLOAD for you game apps
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    Dec 2007
    Thanks guys.. i think i am almost there...
    list loads fine into CL, but when i click launch nothing happens..
    i click game with this command, "LOAD;GAME.SKIN||CLADD;C:\Documents and Settings\sinman\My Documents\Download\arcade\mame32.exe;MAME32 PLUS! 0.111||CLADD;C:\Program Files\KONAMI\Pro Evolution Soccer 2008\PES2008.exe;Pro Evolution Soccer 2008"
    Above click loads game.skin with SC and two items in it.
    I click an item in SC, I then click lauch button with the following command, "SETVARBYCODE;CLTEXT;APPPATH||SETVARBYCODE;CLDESC; APPNAME||LOAD;generic.skin;GAMES;$APPPATH$;$APPNAM E$"
    Nothing happens...
    debug file,
    8/4/2008 5:03:34 PM: Start -- Version: 11/2/2007
    8/4/2008 5:03:34 PM: Master Vol: Volume Control/4
    8/4/2008 5:03:34 PM: GetLineControl Failed: 401
    8/4/2008 5:03:34 PM: No Treble Support
    8/4/2008 5:03:34 PM: No Bass Support
    8/4/2008 5:03:34 PM: Source: Wave=&H1008/1
    8/4/2008 5:03:34 PM: Source: SW Synth=&H1004/2
    8/4/2008 5:03:34 PM: Source: CD Player=&H1005/3
    8/4/2008 5:03:34 PM: Source: Subwoofer=&H100A/4
    8/4/2008 5:03:34 PM: Source: PC Speaker=&H100A/5
    8/4/2008 5:03:35 PM: Sim.WMSGs: 1
    8/4/2008 5:03:36 PM: Sim.WMSGs: 1
    8/4/2008 5:03:36 PM: Enter Exec: False, menu.skin, , False
    8/4/2008 5:03:36 PM: Que Exec: True, menu.skin, "ONSKINSTART", False
    8/4/2008 5:03:36 PM: Executing: ONSKINSTART
    8/4/2008 5:03:36 PM: Leave Exec: False, menu.skin, ONSKINSTART, False
    8/4/2008 5:03:36 PM: Que Exec: True, menu.skin, "ONSONGSTART", False
    8/4/2008 5:03:36 PM: Executing: ONSONGSTART
    8/4/2008 5:03:36 PM: Leave Exec: False, menu.skin, ONSONGSTART, False
    8/4/2008 5:03:37 PM: Enter Exec: False, menu.skin, "LOAD;GAME.SKIN||CLADD;C:\Documents and Settings\sinman\My Documents\Download\arcade\mame32.exe;MAME32 PLUS! 0.111||CLADD;C:\Program Files\KONAMI\Pro Evolution Soccer 2008\PES2008.exe;Pro Evolution Soccer 2008", False
    8/4/2008 5:03:37 PM: Que Exec: True, menu.skin, "LOAD;GAME.SKIN||CLADD;C:\Documents and Settings\sinman\My Documents\Download\arcade\mame32.exe;MAME32 PLUS! 0.111||CLADD;C:\Program Files\KONAMI\Pro Evolution Soccer 2008\PES2008.exe;Pro Evolution Soccer 2008", False
    8/4/2008 5:03:37 PM: Executing: LOAD;GAME.SKIN
    8/4/2008 5:03:38 PM: Enter Exec: True, game.skin, , False
    8/4/2008 5:03:38 PM: Que Exec: True, game.skin, "CLADD;C:\Documents and Settings\sinman\My Documents\Download\arcade\mame32.exe;MAME32 PLUS! 0.111||CLADD;C:\Program Files\KONAMI\Pro Evolution Soccer 2008\PES2008.exe;Pro Evolution Soccer 2008", False
    8/4/2008 5:03:38 PM: Executing: CLADD;C:\Documents and Settings\sinman\My Documents\Download\arcade\mame32.exe;MAME32 PLUS! 0.111
    8/4/2008 5:03:38 PM: Que Exec: True, game.skin, "CLADD;C:\Program Files\KONAMI\Pro Evolution Soccer 2008\PES2008.exe;Pro Evolution Soccer 2008", False
    8/4/2008 5:03:38 PM: Executing: CLADD;C:\Program Files\KONAMI\Pro Evolution Soccer 2008\PES2008.exe;Pro Evolution Soccer 2008
    8/4/2008 5:03:38 PM: Leave Exec: False, game.skin, CLADD;C:\Program Files\KONAMI\Pro Evolution Soccer 2008\PES2008.exe;Pro Evolution Soccer 2008, False
    8/4/2008 5:03:39 PM: Enter Exec: False, game.skin, "ONCLCLICK", False
    8/4/2008 5:03:39 PM: Que Exec: True, game.skin, "ONCLCLICK", False
    8/4/2008 5:03:39 PM: Executing: ONCLCLICK
    8/4/2008 5:03:39 PM: Leave Exec: False, game.skin, ONCLCLICK, False
    8/4/2008 5:04:55 PM: Sim.WMSGs: 1
    8/4/2008 5:04:55 PM: Sim.WMSGs: 2
    8/4/2008 5:04:58 PM: Enter Exec: False, game.skin, "ONCLCLICK", False
    8/4/2008 5:04:58 PM: Que Exec: True, game.skin, "ONCLCLICK", False
    8/4/2008 5:04:58 PM: Executing: ONCLCLICK
    8/4/2008 5:04:58 PM: Leave Exec: False, game.skin, ONCLCLICK, False
    8/4/2008 5:05:00 PM: Enter Exec: False, game.skin, "ONCLCLICK", False
    8/4/2008 5:05:00 PM: Que Exec: True, game.skin, "ONCLCLICK", False
    8/4/2008 5:05:00 PM: Executing: ONCLCLICK
    8/4/2008 5:05:00 PM: Leave Exec: False, game.skin, ONCLCLICK, False
    Aug 2006
    Sun Diego
    Try changing "GAMES" into "RUN" in your launch command line.
    EL CAMINO's Avatar
    Jul 2005
    my bad, the above code is wrong,
    Code:
    "SETVARBYCODE;APPPATH;CLTEXT||SETVARBYCODE;APPNAME;CLDESC||LOAD;generic.skin;GAMES;$APPPATH$;$APPNAME$"
    also i suggest you to use "CLCLEAR;ALL" right after you load the screen that has your games list. that way if you go back to your games list screen, the list will be reloaded.
    Dec 2007
    tried both.. didn't make any difference ..... No biggie, i might just create buttons for each game i guess..
    EL CAMINO's Avatar
    Jul 2005
    lets see what you have, then. the 2 screens and the info from your applications, (path and window name).
    Dec 2007
    It's same as above EC, post 5... just tried your new command.. same deal... those lines path and window names are correct, I test them indivisually... I decided to go different route though.. I am thinking it isn't like i am gonna have a list of 20 games anything like that.. at most maybe 5... so i am just gonna create buttons with image and label... Looks better...
    Anyway, i think i learned new stuff today.. Thanks to you guys.. I'll probably come back to this shortly though...
  1. New generic MediaCar skin
    By febsperanza in forum MediaCar
    Last Post: 11-27-2009, 12:28 PM
  2. Replies: 65
    Last Post: 07-23-2008, 03:03 AM
  3. Uber MDX Configurator Beta Testing...
    By 2k1Toaster in forum FB Software
    Last Post: 06-09-2008, 12:49 AM
  4. "Avic'ted" - Pioneer Styled Skin
    By monkeyracer in forum RR Skins
    Last Post: 10-19-2007, 11:08 AM
  5. Tutorial for installing pycar on Linux
    By kbyrd in forum PyCar
    Last Post: 11-01-2006, 01:59 PM
