Page 13 of 14 FirstFirst ... 34567891011121314 LastLast
Results 121 to 130 of 135
Thread: MJS Gadgets UAS - comming soon to carpc near you
  1. #121
    Apr 2006
    Sydney, Australia
    Maybe I am not getting my issue across to you guys, so the problem is I only have 1 audio output and a MIC input on my MB. The UAS could be my only means of adding 1+ Audio input.
    Basic diagram of what I need to do
    HQCT-->M/B-->AMPS ; FrontEnd-MUSIC/etc-->M/B-->AMPS ; NAV-->M/B-->AMPS (eveything works except HQCT)(WHY, because I have no input to feed this it the mainboard and get this out to the AMPS
    The only input (MIC input) is used for a mic for handsfree via bluethooth for mobile, I could possibly change the I/O operation and use the mic in for audio in, but that would give me mono and no handsfree for phone.
    I currently run 2 seperate amps which I'm connecting to the audio out of the MB [a 4 ch amp & a 2 ch amp bridged for sub].
    The HQCT was an overkill but (I was under the impression it would stream the audio via the USB and output this to the audio jack) so I'm stuck with it and at present we dont have HD radio (think it's on trial) but because I listen to Am fequency I would like to keep this option, also when there is an emergency in tunnels, there is an announcement heard over the radio, so it's a must have for now.
    I do have a SPDIF (which I dont think I can get a digital signal from the HQCT)??so at present I'm not using this, unless there is a way to feed the HQCT into the SPDIF and output this to the audio jack output of the MB.
    My other idea was to change the audio output to an input and use a optical to coaxial (DAC) and get my audio out that way but I've yet to find a EQ with optical in..
    HiJack it maybe is a good invention, but I want an automated solution, not pushing buttons to get audio from the correct device so this is why I ask the questions and dont want to add $$$ to this project if I can avoid it.
    Since the whole thing is out of the car for a refresh I wanted to resolve my audio dilemma. *pokes Hijack in his evil eye*
    This product may or not be right for me, but please feel free to point me in the right direction for a solution.
    Cheers
  2. #122
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Why don't you use the CD In for the HQCT. Most motherboards have that plug for the cd player.
  3. #123
    MySQL Error
    Oct 2004
    you need at least one line in...
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  4. #124
    Apr 2006
    Sydney, Australia
    Quote Originally Posted by MGD View Post
    Hi MGD sadly there is noone If it had that Id have it solved.
    New Car PC Build list in progress
  5. #125
    Apr 2006
    Sydney, Australia
    Quote Originally Posted by mitchjs View Post
    Yes, which is what I dont have, so the next option is to use the HQCT as the input.
    Plug UAS into AUX input of the HQCT and have the HQCT locked onto aux for sound and then take the HQCT 4 channel output and feed this onto my 4 channel amp?
    I assume this is my only option so I am not sure if this will work, but I need code then for the HQCT to stay on AUX when not in radio mode, and then switch to radio when this is in use?
    Am I making sense?
  6. #126
    MySQL Error
    Oct 2004
    kosti, that is VERY messy...
    get a USB line in, like:
    http://cgi.ebay.com/NEW-BEHRINGER-UC...item5883e00c7e
    I am currently working on a USB Audio Solution, but im not yet ready... it will be about the same $$$ anyway
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  7. #127
    Apr 2006
    Sydney, Australia
    Thanks for the link...if I only could find this amp Performance Teknique ICBM-5.1 Dolby Digital Amplifier, optical and coaxial inputs!
    CLICK HERE
    I don't think it's that messy mitch
    AUDIO OUT FROM MB into AUX on HQCT from HQCT to AMPS. saves me adding in another USB device (since I have none left - unless i get a hub).
    I've written to Datalex who have provided an application that starts the HQCT into AUX, what I haven't done is work out how to get this working properly and have it switch from aux to radio and when radio closes go back to aux.
    I realise this isnt the appropriate thread for this dicussion, maybe I'll make a new one in the audio section
    I think this my solution would be the best option i have without additional hardware, unless i change MB which crossed my mind to a dual atom 330 board for zotac
  8. #128
    Apr 2006
    Sydney, Australia
    Ive started a new thread in the audio section for suggestions than can be posted there if anyone can help me with this with my battle for Audio in.
    HERE
  9. #129
    Maximum Bitrate bratnetwork's Avatar
    Oct 2007
    Haledon, NJ
    I have had a UAS for a bit now and it is a neat and helpful little unit. Recently it seems to be having a few issue. First issue is that it seems to feeding some distortion and noise into my soundcard. If I unplug the UAS from the soundcard it is silent, if it is plugged in even with no inputs plugged in it still give out pretty significant noise. This has not always happened, started recently. Also now if I plug in my keyboard it loses the uas and I get like 20 popups that tell me this.
    The first problem I was thinking maybe ground loop, but now with the second problem I'm wondering hardware malfunction? What do you think?
  10. #130
    MySQL Error
    Oct 2004
    your using the tray app... thats whats making the popups...
    but besides that... maybe noise on your usb power...
    i would say, try on another pc... plug it in to usb, and listen to audio...
    still have some noise, i sugguest you contact me on my site, and arrange a repair, just pm me
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. a warning to all prospective carputer installers!
    By mbkowns in forum General MP3Car Discussion
    Last Post: 08-19-2008, 05:37 AM
  2. How can I use a laptop as a carpc?
    By turbocad6 in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 07-11-2007, 01:55 AM
  3. MP3Car CarPC State of the Union 2006
    By SwapMeet in forum General MP3Car Discussion
    Last Post: 10-18-2006, 09:32 PM
  4. Replies: 33
    Last Post: 09-01-2005, 05:14 PM
