Page 2 of 14 FirstFirst 123456789101112 ... LastLast
Results 11 to 20 of 131
Thread: MJS Gadgets UAS - comming soon to carpc near you
  1. #11
    Variable Bitrate hailrazer's Avatar
    Mar 2008
    Columbus, Georgia
    Quote Originally Posted by quantum View Post
    So, with this I could plug in four 1/8" jacks from different sources and select them in RR like an A-B (and C-D) switch? Is that correct?
    How cool is that!!! I was JUST NOW looking at an A-B switch do do exactly the same thing here http://electronicsusa.com/mk1and2.html.
    This is way better. Count me in Mitch!
    That's the exact switch I have now.
    Looking forward to an automatic one
  2. #12
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Quote Originally Posted by mitchjs View Post
    software support is complete
    its built into my version of RR
    and a API is avail for any other applications
    plus a nice windows TRAY application
    its gonna be $55, if all goes well, it will be available right here at carmp3.com store too
    Very nice Mitch! It would be nice to have an extension plugin for this, this way the RR source does not need to be altered to use it. Looks like another $55 to spend on the CarPC
    Oh, BTW, I think you meant to say it will be available in the MP3Car Store (store.mp3car.com)
    My Fiero Build Thread
  3. #13
    MySQL Error
    Oct 2004
    Davedog, no
    it will do more then 1vpp
    thats what the specs are BASED ON
    NOTE THE WORD "WITH"
    with 1vpp signal
    SNR aprox -110db
    THD .005%
    Seperation 90db
    at 5v, u should be able do 2vpp with out clipping
    but not much more
    else u will need to externally power it. and i dont see the need at this point
    mitch
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  4. #14
    MySQL Error
    Oct 2004
    JOhnwpb, i already got it in natively into RR
    could add it as a plug in, but i dont know how to make rr plugins
    ill let someone else do it for me..
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  5. #15
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Mitch, you have done a fantastic job with incorporating the XM, Sirius controls seamlessly into RR.
    The problem is, and its not your fault in any way, is that the source code you have is almost a year old, as that was the last public release of it. In that year's time, many bugs were squashed, new features added, and many fixes have been made. I think there have been like 4 releases since the last source code release, one at the end of November, one in December, one in February, and then one in May.
    This is just a partial list from 2 of the RR updates that I could find:
    -Added SETVARBYIND command
    -Added fade support to "file" and custom indicators
    -Added ADD1 dynamic command for scripts
    -Added iList Position Slider Codes
    -Added RADIORESET command for all radios
    -Improved Resolution setting to not change resolution not present
    -Improved Audio/Video Art preview
    -Improved INC Definition so it can accept variables
    -Improved IMG Def so it can accept full paths
    -Fixed Weather not pulling from the Internet
    -Improved Ipod Support for Newer models
    -Improved SiLabs Radio Support
    -Set default background on transparent skins to black if none specified
    -Fixed Built-in video player "SELECT" bug
    -Fixed Radio Playlist issue when using line in plugin
    -Fixed issue with SETPATH not selecting first item of list
    -Fixed issue with iList long scroll when using large lists
    -Fixed issue with loading iList on menu.skin
    -Fixed issue with SEARCHFILES not updating song titles with lazytag=false
    -Fixed issue with Indicator codes from extension plugins
    -Fixed Issue with HEADING indicator
    -Fixed Issue with Silabs not starting at last used Frequency
    -Fixed Issue with SEARCHFILES when using iLists with no icons
    -Added support to transparent iLists
    -Added support to poll playlist paths directly from Flash
    -Added support to poll label info directly from Flash
    -Added LOADLIST support for VIDEO player
    -Added support to load M3U files in VIDEO browser
    -Added OSKTEXT command to set text on OSK/NUMOSK
    -Added command to wait execution of commands from Flash
    -Improved LazyTag to work with audio browser
    -Fixed Hibernation issue with iLists
    -Fixed issue with sel colors and tag display in TEXT MODE iLists
    -Fixed issue with unselected text color of Custom Lists
    -Fixed issue with CUSTOMCL not auto-refreshing
    -Fixed issue with ShowExtensions option in iLists
    -Resumecheck of 30 seconds without updates instead of 5
    -Updated Web Plugin to work with "RoadRunner" in the .skin header
    -Ability to use Solid progressive sliders
    -Ability to turn on and off iLists Globally
    There are also 20 or so new things, that have been added. Guino has not created the documentation for the additions, thus he asked that they not be listed when I posted the last beta for 05/27.
    If the code for the new audio switcher is in your RR version, then anyone wanting to use it will have to use that version, and lack all the above fixes and enhancements. This will continue to escalate when Guino releases another version, and you version does not have those fixes and enhancements.
    Have you contacted Guino, to see if all if your fixes can be incorporated into the official source?
    Again, you have done an amazing job with the audio switching, something RR has needed for a very long time, and it it were not for your research and development for the HD cable, I would not have HDRadio in my car. So I am not critisizing in any way what so ever, so please dont think of it like that.
    It's just that its gotten to to a cross road so to speak.. The end user is forced to choose between 2 different Road Runners, depending on what features are more important to them.
  6. #16
    FLAC Griff1's Avatar
    Nov 2005
    Midlands
    I see your point john,in plug-in form we could add it to the any release but thats not the real issue is it.
    It looks like Guino is tiring of RR and still we can't get hold of more current source code,as a result RR is slipping into chaos,uumpteen releases going around and most of em buggy.
    What we're seeing here is IMHO the shape of things to come,reminds me of Skippy76's days.
    EDIT:What i'm saying is we need to get hold of the latest source asap and come up with a Dev plan of phases where each contributor gets the source in turn and adds to it followed by a month or so of beta testing followed by a release of both RR and its current source.
    P4 2.8 HT, 512Mb Ram, 60Gb 2.5 HD, M4-ATX, SB Audigy2, BU353, Lilliput TS,Soundgraph Imon VFD,SONY Optiarc dvd Burner,RideRunner, iGo8, Custom Freedom 2.1
  7. #17
    Nov 2004
    St Louis
    Please don't remind me of those days
  8. #18
    MySQL Error
    Oct 2004
    yes, john, i have been in contact with guino, you and others seem to miss this one point
    if guino merges my changes, im out... since he at this point is not able to release the source
    until he can release, or until im done, make the choice
    1. slow HD/XM/Sirius
    2. fast HD/XM/Sirius
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  9. #19
    MySQL Error
    Oct 2004
    as for plug in,
    I DONT KNOW HOW TO MAKE RR PLUG INS
    and technically, i dont want to know...
    but... if someone wants to take it on, the plug in for the audio switcher
    would be CAKE
    the vb6 code, is so small
    someone interested?
    John can u?
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  10. #20
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    as for plug in,
    would be CAKE
    someone interested?
    John can u?
    mitch
    i can mitch. You make things so easy it'd be no problem.
    Live mp3Car Facebook Chat
  1. a warning to all prospective carputer installers!
    By mbkowns in forum General MP3Car Discussion
    Last Post: 08-19-2008, 05:37 AM
  2. How can I use a laptop as a carpc?
    By turbocad6 in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 07-11-2007, 01:55 AM
  3. MP3Car CarPC State of the Union 2006
    By SwapMeet in forum General MP3Car Discussion
    Last Post: 10-18-2006, 09:32 PM
  4. Replies: 33
    Last Post: 09-01-2005, 05:14 PM
