Results 1 to 10 of 11
Thread: once again broken video
    bmo
    bmo is offline
    Low Bitrate bmo's Avatar
    Feb 2005
    ohio
    Not to long ago I had the same problem but, It fixed it self or I did something to fix it(didn't know what I did)
    All video types play fine in winamp and mpc outside RR.
    I am using the built in video with the mpc location in the rr directory (using FFdshow). When I am in rr in video only one video plays... the one that starts automatically. When I go into browser to select a differnt video, I click on it and it returns to the video screen with the same video that was playing still playing. If I back out to the main menu I see that winamp has started to play the video that I selected in the browser... For some reason when ever I choose a new video, winamp always opens it up and starts playing it, but not under video.
    I hope you can follow the problem I am having. I have changed file association to wmp, to mpc to winamp to... everything. Deleted video.ini resume.ini ...many times. Tried almost everything that I can think of. Reinstalled RR, winamp, mpc...
    Is winamp or mpc supposed handle video when in the video skin? I am lost, I don't want to install another program for video so it half way works, when it worked fine before.
    Please any help or ideas
    Bmo
    bmo
    bmo is offline
    Feb 2005
    ohio
    really... nothing ???
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    built-in video isn't MPC. According to a recent search i did, RR uses "WMP API," whatever that means, as the built-in video player.
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    Jan 2006
    dis-associate your video files from winamp....
    then go to your video folder and right click on all the diff formats, avi mpeg etc... open with / mpc "always open using this program"
    bmo
    bmo is offline
    Feb 2005
    ohio
    Tried that also but, gave it anougther go. In winamp/agent I removed and video associtions. Then associated the video files to mpc. Still didn't work. Then in RRconfig I unchecked use built in video player. Then it started to work again, well almost working. RR has a hard time coming back to a focused screen. Usually you tap the screen and the controls would show up. It's kind of a shot in the dark now. I did notice that when I closed the video palyer(it's using mpc now) manually that the controls were behind it.
    I did go back and check the used built in video player, and it didn't work again. So for now it's unchecked. I hope I can work this all out. I don't watch alot of videos in the car. It's mainly for my kids on the rear monitors. Makes the ride so much quiter.
    Aug 2006
    Sun Diego
    do you have WMP installed?
    bmo
    bmo is offline
    Feb 2005
    ohio
    yes i do. It plays all videos outside rr fine.
    Nov 2005
    I dont think this is specifically useful to you, but then again.. you are probably willing to try anything.
    http://www.mp3car.com/vbulletin/rr-f...look-here.html
    Variable Bitrate navputer's Avatar
    Jan 2007
    DFW Area
    Quote Originally Posted by Iceman_jkh View Post
    Actually, this does help. The first thing in that list is to uninstall Divx or other codec players that might cause problems. I had to uninstall my Divx player and that fixed my problem with the video not showing with mpc.
    Gee
    Variable Bitrate dhantiflag's Avatar
    Nov 2006
    Mentor, OHIO
    i got the same problem too bmo... ima try that link tho
    maybe its a mentor thing?
  1. Trouble with PCI video card install ... help!!!
    By DonkeyBoy in forum General Hardware Discussion
    Last Post: 08-10-2005, 05:22 PM
  2. Build my PC?
    By diddy0071 in forum Newbie
    Last Post: 07-11-2005, 01:00 AM
  3. Media Car video player
    By MatrixPC in forum MediaCar
    Last Post: 03-22-2004, 01:33 PM
