Results 1 to 10 of 16
Thread: How to Config RoadRunner?
    Aug 2008
    Hi guys sorry if this has already been posted but I've been searching for days and haven't found anything...
    I am currently running iGuidance with road runner and using Xport.
    using Xport I've shared com port 3 to 4 and 5..
    my iGuidance reads com 4 fine but how can I get road runner to read com 5? is there a file or something that I have to edit?
    I've been looking around and read post after post but no one says how to get roadrunner to read a com port.
    please help.
    and thank you.
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Those dang noobers.
    Have you looked around in the RR Config program? I'm pretty sure the setting is in there...
    Tidder
    Try RevFE
    Aug 2008
    actually I did.. and there is nothing about changing the com port.
    sorry I know it's a nob question.
    Sep 2003
    New Mexico, USA
    Well if you can't find it in rr config, you can change it in rr.ini file. If it's a fresh install, it'll show up as gpsport=0.
    EDIT: Tho I'm sure under the GPS section in the config program, there's a gps port setting there. I'm sure of it. Unless they've changed the config proggy recently.
    Tidder
    Try RevFE
    Sep 2003
    New Mexico, USA
    path to rr.ini on a typical install is C:\Program Files\Road Runner\rr.ini
    Sorry, shoulda mentioned earlier.
    Tidder
    Try RevFE
    Variable Bitrate Ramanator's Avatar
    Feb 2007
    Motor City
    Quote Originally Posted by Athlon07 View Post
    please help.
    and thank you.
    First, start Xport. Now set the input com port to the port of your GPS receiver.
    Next, In the lower part of Xport, Check "Enable Service" then, under OUTPUT set up the virtual com ports you would like to use ( 4 and 5 ).
    Now Put the 4 in Road Runner's GPS config, and 5 in your GPS program. So now your Receivers com port is split into two virtual ports. Hope this helps
    If you cant DODGE em, RAM em.
    Aug 2008
    Thank you so much guys! and once again sorry for the nob question, i am sure you guys might be tired off that question!
    Sep 2003
    New Mexico, USA
    Actually, that one was a first for me. Usually it's more along the lines of skins and screen config and junk. I'm dying to find out why you don't have GPS options in your config program though...
    Tidder
    Try RevFE
    Aug 2008
    Quote Originally Posted by Tidder View Post
    I just uninstalled and reinstalled roadrunner and it pop up under the GPS Settings...
    before it was just a blank grey window.
    thanks alot for your help... you guys are great got it working now.
    Sep 2003
    New Mexico, USA
    How weird. I have issues with the rr config proggy from time to time, but nothing like that. Usually my issue is it just won't run.
    Tidder
    Try RevFE
  1. RRTMS - RoadRunner tire monitoring system extension plugin
    By Robby BMW in forum RR Released Plugins
    Last Post: 12-27-2014, 01:19 PM
  2. How to setup iGuidance GPS for RoadRunner
    By MatrixPC in forum RR FAQ
    Last Post: 05-22-2009, 08:29 AM
  3. Music in roadrunner
    By m60power in forum Road Runner
    Last Post: 04-24-2008, 10:21 PM
  4. Newbie with a Roadrunner Config Question
    By jay2000 in forum Newbie
    Last Post: 07-16-2007, 12:24 AM
  5. Roadrunner Skinning Tutorial
    By Meelobee in forum RR Skins
    Last Post: 12-30-2005, 07:28 PM
