Results 1 to 5 of 5
Thread: Flash Question?
    Jul 2008
    Lee's Summit
    Flash Question?
    Why are you all using a guide to move the needle in the speedometer? What would you not use some like this. "needle._rotation" and then toss in something like this?
    if (needle._rotation<var1*2 && needle._rotation>=0) {
    needle._rotation += 2;
    } else if (needle._rotation>var1*3 && needle._rotation>=0) {
    needle._rotation -= 2;
    } else if (needle._rotation<var1*3 && needle._rotation<0) {
    Can anyone explain why it will not work this way... I don't have a real way of testing in just yet but my guess is it will work.
    and you don't need all them frames... Just frames to make it work.
    Just asking? If there is a reason it is done the other way I would to know before I put all this effort into coding my flash gauges...
    Troy
    Batmaninls
    www.evorbust.com
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    i dont really see a reason this wont work.. thats just ALOT of conditionals for 365 degrees of rotation. I guess either way its alot of work though.
    Live mp3Car Facebook Chat
    Jul 2008
    Lee's Summit
    Well it reduces the number of frames on the file. Making it smaller I believe. If you think it will work out that sounds great... and the RRFusion will do ok with it correct... I'm needing to come up with my inputs so it can read them.
    like
    _root.gpsspd
    _root.cpu
    _root.gps
    __root.stc (my "state of charge")
    _root.Avolt
    _root.volt
    _root.amp
    Will all these work ok for collecting the data from RR and providing it to Flash?
    I can't wait to show you all this gauge cluster. It's turning out to be a work of art.
    The photoshop file is a monster but it's will be worth every meg...
    lol
    Sonic Let me know on this stuff will you please.
    Troy
    Batmaninls
    www.evorbust.com
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by Batmaninls View Post
    like
    _root.gpsspd
    _root.cpu
    _root.gps
    _root.Avolt
    _root.volt
    _root.amp
    lol
    Troy
    as long as its a supported rr label AND defined in your .skin file. RRfusion doesnt declare _root.volt _root.amp etc, but you have the right idea. Lemme know when ur ready to implement it and i'll help if you need
    Jul 2008
    Lee's Summit
    Ok thanks...
    Batmaninls
    www.evorbust.com
  1. Replies: 3
    Last Post: 12-11-2007, 06:07 PM
  2. Replies: 5
    Last Post: 04-08-2007, 09:38 PM
  3. Forum Etiquette
    By Enforcer in forum Newbie
    Last Post: 01-09-2006, 06:58 PM
  4. Can this be done in RR and flash
    By tolisn in forum Road Runner
    Last Post: 06-16-2005, 02:57 PM
  5. Can Flash resize?
    By froop in forum Road Runner
    Last Post: 04-16-2005, 11:58 AM
