Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: Garmin Mobile PC question
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    Does Mobile PC allow for destination entry by coordinates? Just making sure before I buy this, I am going to make a plugin to integrate this to RR if it is worth the while. IG 2009 looks pretty good and I have been using IG for years but deifnitely looking for something fresh.
    New Age Garmin - Skin for RR
    Maximum Bitrate Woofnstuff's Avatar
    Oct 2007
    Auckland
    if you can get that bugger into RR you would be legend
    i went back to nroute in the end still have not brought a copy of mobile PC, as there is no local version, so im using after market maps which work fine, but its pointless if i cant embed it into RR.
    im happy to help test things if you need.
    Constant Bitrate insaneramman's Avatar
    Mar 2008
    South Carolina
    I have Garmin. As much as I'd like to see this in RR I don't think you can. I will ck tomorrow to be sure.
    Oct 2007
    Auckland
    also check this forum.. as mobile PC dosnt like working with gps splitters,
    so if you have more than one thing that needs a gps signal... you may be stuffed there too
    http://www.laptopgpsworld.com
    Oct 2006
    Midlothian, VA
    BTW, yes you can search for a destination via coordinates.
    Nov 2006
    Quote Originally Posted by Woofnstuff View Post
    Hi GMPC will not work with GPSGATE, it works fine with on my tablet pc with XPORT
    Mike
    Tasmania, Australia
    Aug 2008
    Quote Originally Posted by Commodorecrazy View Post
    Haven't tested extensively, but so far I've also found GMPC works fine with XPort on my laptop with a BU-353.
    Oct 2007
    Auckland
    ok sweet, heard a while ago the xport would freeze or lag a bit with GMPC
    must try the latest version then
    Nov 2005
    xport works fine with gmpc here.
    1. is there already a solution for rr with good OSK (on screen keyboard) support. saying this, it works wit rr OSK but some key are not working, i.e. backspace
    2. would like to set a label in rr which is set whenever i approach a poi (speedcam) and rr shows me some warning text on every screen. how could i integrate this into rr (garmin sdk is availablek, anybody used it yet for pc edition)
    Aug 2006
    West Allis, WI
    Quote Originally Posted by upspace View Post
    I will be working a script for a OSK specific to GMPC once I am convinced I need it. The plan as of now is working out a way to mount a keyboard (mini industrial) in to my center console. I hate OSKs, nothing worse than trying to type on a keyboard that is vertical and partially glared from sun.
  1. Need help with RR and Garmin mobile pc
    By viagra in forum Road Runner
    Last Post: 05-26-2008, 05:55 AM
