Results 1 to 10 of 12
Thread: winamp vis fullscreen trouble
    Maximum Bitrate americasfuture2's Avatar
    Apr 2007
    Edmond, Ok
    how can i make winamp vis go to fullscreen just by tapping the vis icon on my RR skin. BMV2 being used btw.
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    "VISU" will be your cmd to start visuals in a defined area, and,
    LOAD;Vis_full.skin||VISU||SETPATH;$PLAYLISTPATH$ this will be for fullscr visuals, notice the skin launch at the begining, you will need the skin file to have A
    A,xx,xx,xx,xx line which covers the whole area or the area you want visuals to be in.
    this is what i use in my skin but i use it as a Press & hold func,
    Wants to make it harder monkeyracer's Avatar
    May 2007
    Lakehood, CO
    If you use AVS:
    Just change "VISU" to "FULLAVS"
    2007 Chrysler PT Cruiser TE
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
    Favorite thread EVER!
    Apr 2007
    Edmond, Ok
    where do i find all this?
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    In the Root RR folder, there is a file names SkinCommands.txt. You will find it in there. If you want to know how the visualizations work, just do a quick search on the file for "vis"
    My Fiero Build Thread
    Apr 2007
    Edmond, Ok
    still not helping
    Apr 2007
    Edmond, Ok
    Quote Originally Posted by monkeyracer View Post
    If you use AVS:
    where do i find this visu? its not in rr.ini
    i am using avs
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    visu is somthing you have to set up in winamp and rr, open winamp withoput rr
    CTRL - P \ Visu near the bottom left pane
    highlight advance visu in right pane and hit start at the bottom
    now hit config
    new box appears in the tabs hit settings \ presets
    in the right pane you will see all tab , if you have no other avs folders like spectrum
    leave this alone ,but de-tick random. now close winamp
    open rrconfig
    under MUSIC page 2
    check avs in the text box along side type "!Winamp Gen!AVS" without Quotes i think it is.
    the section below that is for trans and fade in you will have to play with these setting to your liking.
    now save and run rr
    you must have a App area defined in the skin plus the start and next/prev buttons to control avs, if you are using DFX say they can be found in the main menu and audio player .
    Apr 2007
    Edmond, Ok
    hm, even the last bit starting with save and run RR has me confused.
    wow, i think you all feel like i do right now when i try and explaining a cars computer to people. not carputer, my fiero's ECM.
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    ok if you are like everyone else on here , you would have downloaded DFX by john, look in his help file for setting up spectrum analyser,
    I have the same in my help file in my skin release MKIII Imag'ine , but hands up its a copy of johns visual set up in his help file so which ever you use it will get things working.
  1. WinAMP 5 Comes to front on launch
    By macbrando in forum Road Runner
    Last Post: 09-05-2007, 09:01 PM
  2. WinAmp visualizations in Windows Media Player (almost working)
    By NoPistonPC in forum Software & Software Development
    Last Post: 08-21-2007, 07:11 AM
  3. RR and Winamp VIS...
    By DaPCWiz in forum Road Runner
    Last Post: 11-01-2005, 07:17 PM
  4. EPIA video + Winamp standby problem
    By crisr in forum General Hardware Discussion
    Last Post: 08-25-2004, 07:16 PM
  5. New fullscreen winamp control plugin
    By jumpoint in forum General Hardware Discussion
    Last Post: 03-05-2000, 04:07 PM
