Page 3 of 16 FirstFirst 12345678910111213 ... LastLast
Results 21 to 30 of 153
Thread: 09/10/08 TAKE 2 OFFICIAL MJS Road Runner Release
  1. #21
    Wants to make it harder monkeyracer's Avatar
    May 2007
    Lakehood, CO
    nice, i just got take 2, one of the first, sliders work!
    2007 Chrysler PT Cruiser TE
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
    Favorite thread EVER!
  2. #22
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    As well as a 10 disk changer
    Ok, last post, I promis hehehe Going to bed now.... have to be up at 3am to go to the airport, and will be gone for 2 glorious weeks, hiking, horse back riding, and white water rafting!
    Great work on this Mitch!
    Just a note, "the official MJS RR release" title of this thread may confuse people. As you had like 5 threads with different rr releases that you were using the older 11/02 code. Maybe something like "Official RR release Guino and Mitch merged code"... as Guino did have a LOT to do with this release, and it is using his latest source.... Just a thought
    My Fiero Build Thread
  3. #23
    Constant Bitrate jarred's Avatar
    Sep 2000
    Stockton, CA USA
    Does the Mp3Art plugin work properly with this release?
    Thanks,
    Jarred
  4. #24
    Mar 2006
    Colorado, but Canadian!
    Ok, I worked tonight so I got to use it for 5 hours.
    Things I noticed that did *NOT* happen with my older version:
    Every time RR Exits and restarts, Winamp volume goes to 0, and Line-In (Sirius), drops to a rediculously low level so I have to manually slide them up with the EQ. This also happens like 50% of the time when resuming from standby.
    I got a generic windows "RoadRunner stopped working" error after standby in music, resume in music (with winamp at 0 magically) and clicked Sirius RR froze and shut down. I have never had RR freeze in the entire time I have used it.
    Also Sirius displays 0/ every resume instead of the previously playing song like it used to, and takes a long time to update.
    GPS speed-volume is also taking longer to kick in from resume than it has every before. Also if I am on iGuidance, I resume and start moving, within the second my position is changing on the map. RoadRunner used to be instant like that too with the volume. Now it takes about 3 seconds or so and then starts to go up.
    I go into standby at least once every 10 minutes, usually much more often with all the deliveries, so these couple seconds extra with GPS speed, and having to always change the volume in the equalizer is a royal pain in the ***. Let me re-iterate, everything was working peachy pre-update.
    Ideas on any of this?
    1.9in x 2.9in -- 47mm x 73mm
  5. #25
    Constant Bitrate slvrsol's Avatar
    Mar 2007
    Quote Originally Posted by jarred View Post
    Thanks,
    Jarred
    Doesn't work for me either.
  6. #26
    Jul 2006
    i have mitch HD radio cable and i cant seem to find AM Band Button for the BMV skin... any help switching AM/FM + setting presets would be appreciated.
    2006 TOYOTA COROLLA XRS
    EEEPC 701
    Windows XP Pro
    RoadRunner
    freefone 1.4 Alpha
    Bluetooth Handsfree utility
    Garmin Mobile PC
    Bybyte Double-Din LCD Frame 629 LCDFR629
    Directed DMHD-1000 HDRADIO
  7. #27
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    a work around for the missing AM button is to direct tune and just type in the AM station.
    Other than that great work mitch You have hereby been nominated quickest coder in the land.
  8. #28
    Constant Bitrate almera's Avatar
    Aug 2004
    Thanks for the separate new release..
  9. #29
    MySQL Error
    Oct 2004
    Quote Originally Posted by veiloctane View Post
    has nothing to do with the release
    am and fm is managed by the skin
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  10. #30
    MySQL Error
    Oct 2004
    Quote Originally Posted by 2k1Toaster View Post
    you got some seroius issues, you will need to narrow down your problems 1 at a time
    there are NO known issues, fyi you should have been testing my builds for some time. i dont know enought about your system to help you... but make sure you read the notes... which ill post again, maybe ur not running on normal Hard Drive based machine, and some files cant write.. i dont know
    srcache.ini MUST be able to write!! for example
    one thing is for sure, i KNOW you have...
    fadeinvolume=true
    fadeinvolume is so buggy, DO NOT USE IT
    EVERYONE DO NOT USE IT
    it needs a complete concept rewrite (and its complicated, audio isnt managed well in RR)
    thats why your volume is messed
    set
    fadeinvolume=false
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. PhoneControl integration w. Road Runner problem
    By Broendbjerg in forum PhoneControl
    Last Post: 11-05-2007, 12:01 PM
  2. Road Runner and Iguidance v4 locks my computer.
    By kickercivic1 in forum Road Runner
    Last Post: 10-13-2007, 08:49 AM
  3. How to Speed up Road Runner
    By JohnWPB in forum RR FAQ
    Last Post: 09-15-2007, 02:58 PM
  4. Replies: 18
    Last Post: 08-03-2007, 09:02 PM
  5. Road Runner Shell Issue
    By B|ade in forum Road Runner
    Last Post: 05-24-2007, 06:00 AM
