2k1toaster,
1st
Also I notice that the Sirius file list, only has 160 channels? Why not use the correct current list that goes past 200? There are some channels around 183 that I listen to sometimes, using your hardware, so it isn't a hardware limitation!
your are wong, ALL channels that you SUB to will be avail..
you maybe need to read all the MJS threads...
you do have FILE WRITE PERMISSIONS on srcache.ini right?!?!?!?!
the fade in volume WILL NOT WORK!!!!
and its completly wrong
sorry, unless u switch to 100% winamp audio managment, ie use winamp line inplug in for sirius, it CANT and WONT work correctly!!. i really dont want to explain the code too much further in this thread
also read the PM i sent you...
-Thanks
Mitch
www.rush2112.net
Sun, Come shine my way
Wind, Carry me home
The piece of me that died
Will return To live again
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
Live mp3Car Facebook Chat
course no one reads notes...
FOR XM / SIRIUS
in RR.ini
my recomended 1st time run is...
srusecache=false
xmusecache=false
then after all channels are loaded switch them to true
(but you dont have to, it is faster with it cached)
(but live load i could argue is better)
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
live load is real quick! yay for live load
Well I will double check the sirius file being read only, but as for fade in volume... why?
I am a programmer too, give it to me as to why.
It worked perfectly before. For a year no problems with it. Update and now it "wont" work magically. Just like those other things I mentioned. Worked before, now dont. I will be figuring them out later, I just thought bringing them to the attention of someone that worked on the source and knows what he changed from the older version for the new version will know why better than me who has not looked at the RR source. It seems easy to implement a correct fade-in on all lines.
1.9in x 2.9in -- 47mm x 73mm
2k1toaster, it didnt work before!!! it never worked
you think it worked, cause RR ONLY EVER RESUMED TO WINAMP!
before my build, did SIRIUS comeback on if you where listening to sirius when you hibernated??!?!?!
did you READ YOUR PM!!!!!!!
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
Yes I read the PM. Havent acted on it yet as I am in uni all day every day.
And yes actually it did work. If I was playing music and went to standby with fade on, when I resumed, the music faded back in. If I went to standby with sirius playing (and I was using the winamp line in) it started right back up and faded in. Also in either case GPS speed resumed instantaneously too. So it was a fade in then 1% jumps to volume dictated by GPS speed.
Something in this release BROKE it is what I have concluded. Maybe it became broken in the last public release I don't know. I usually dont upgrade what is working. But touting better sirius control (which on my old one did take a bit to change channels, and sometimes I had to switch to music, and then back to sirius if the channel didnt want to change which I have not had to do since the update) made me want to update so I did.
The way it was before and should be:
Idle - Displays "OFF" image
Mouse over button area - Displays "ON" image in the specified button region
Click on button - on the click, displays "DOWN" image, and reverts to previous when click is released.
Currently, (broken)
Idle - same as above
Mouse over button area - same as above
Click on button - On the click, does nothing, when click is released, the "DOWN" image shows for half a second and then reverts to previous.
Also, scrolling text and iLists are still not fully transparent, I thought this might have been something on the list of things to fix...
2007 Chrysler PT Cruiser TE
Car PC Progress:
View my
Worklog
Road Runner Skins
Website
Favorite thread EVER!
NO monkey, it doesnt
your whole post implies that i would let a bug like that out...
click on button, down image shows, and stays shown till i release!!
it it working perfectly!
temporary remove all plugins, and try
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
